How To Calculate Catapult Trajectory
In summary, the conversation discusses the process of building a catapult that can launch a bean bag a certain distance and the calculations involved. The relevant equations and variables are also mentioned, and it is suggested to experiment with different springs or use a spring scale to find the stiffness. Other tips include using a projectile motion problem and conducting an experiment to find the spring constant.
tesla93
23
I have an assignment where I have to build a catapult that is able to launch a bean bag any distance between 8-12 metres. My teacher will give me a random distance on the day it's due, and I have to be able to adjust the catapult in order for it to launch that distance. I'm having a bit of a problem with the calculations. How would I go about solving for the displacement of the spring needed to launch a certain distance?
Relevant Equations:
F=ma
W = Fcosθ(d)
Ek = 1/2mv^2
Eg = mgh
Fx = kx
Ee = 1/2kx^2
d = v1t + 1/2at^2
v2^2 = v1^2 +2ad
Attempting the Calculations:
mass of beanbag = 0.048kg
distance needed to travel = let's say 10m
Fx = 10N (using a spring force gauge)
x = 0.25m
launch angle = 50 degrees
Fx = kx
10 = k(0.25)
k = 40N/m
Ee = 1/2kx^2
= 1/2(40)(.25)^2
= 1.25
In the beginning it has elastic and gravitational potential energy so
Ee = Eg
1.25 = 0.048(9.8)h
h = 2.657m is this the max. height of the bean bag?
I'm thinking I need to solve for acceleration and velocity so that I can use
v2^2 = v1^2 = 2ad and that would be my distance, then I can work backwards using different distances and solve for Fx and x, but then I think I also need to use the launch angle in the calculations, and I don't know where to do that.
Thanks for looking at my post.
Just a tip, its probably going to be a lot easier to just experiment until you get it firing within that given range. Perhaps have a set spring/bungee and figure out how far you need to pull back the arm to have it hit different distances.
But if you were to actually calculate it you would need to know the spring stiffness 'k', then assuming its linear meaning it follows F=kx (which it may not) then the energy stored in the spring would be E=(1/2)kx^2. Next you would need to set up the equation for the angular kinetic energy of the throwing arm. In that equation the angular speed would be the unknown. Then set the stored spring energy equal to the kinetic energy of the arm at release to solve for the angular speed. From that point its a projectile motion problem.
Hey thanks for the reply,
Yeah I figured just experimenting would be the best route to take.
How would I know the value of k of the spring though? If I go to a store and buy a spring would it say what the stiffness is? Or could I just use the spring scale to measure the force of the spring, use the that to find the stiffness and then solve for energy stored?
Thanks again!
To find 'k' you would simply apply a known weight or force to it and measure how much it deforms. Do this a few different times with different weights and plot the results (force vs displacement) using something like excel. Then if its linear it will form a straight line (or close to it) with the slope equal to 'k'.
Also depending on what you use to build the catapult, you made need a fairly capable spring that may be harder to find. When I built one awhile back i made mine from wood, mainly 2x4's and just used a couple bungee cords until i got it firing a good distance.
You can do a nice experiment to figure out the constant. Get a set of known weights and hang the weights from the spring and measure the extension. Do this for a lot of different weights and graph the resulting data points on excel. Use a best fit curve and you can find a function that matches your spring. It should be approximately linear for relatively small extensions. If you set it up right, the slope of the line will be the spring constant. I did this experiment about a year ago. It is quite fun.
Haha you must have posted this while I was typing my reply.
Yeah i think so..i laughed when i saw your similar post almost instantly after mine.
Haha okay this makes much more sense now. It funny cause I actually did an investigation on Hooke's Law a couple weeks ago doing what both of you guys said to find the constant of a spring, but I totally forgot about it. Thank you guys so much!
1. How do I calculate the trajectory of a catapult?
To calculate the trajectory of a catapult, you will need to know the initial velocity of the projectile, the angle of launch, and the acceleration due to gravity. You can then use the kinematic equations to determine the horizontal and vertical components of the projectile's motion.
2. What is the formula for calculating catapult trajectory?
The formula for calculating catapult trajectory is:
Horizontal distance = (initial velocity * cos(angle of launch)) * (initial velocity * sin(angle of launch)) / acceleration due to gravity
3. How does the angle of launch affect the trajectory of a catapult?
The angle of launch has a significant impact on the trajectory of a catapult. A higher angle of launch will result in a steeper trajectory, while a lower angle of launch will result in a flatter trajectory. The optimal angle of launch for maximum distance will depend on the initial velocity and other factors such as air resistance.
4. Can I use the same formula to calculate the trajectory of any projectile?
Yes, the same formula can be used to calculate the trajectory of any projectile as long as the initial velocity, angle of launch, and acceleration due to gravity are known. However, factors such as air resistance and wind may need to be taken into consideration for more precise calculations.
5. How accurate are the calculations for catapult trajectory?
The accuracy of the calculations for catapult trajectory will depend on the accuracy of the initial velocity and angle of launch measurements, as well as other external factors such as air resistance and wind. The calculations can provide a good estimate of the trajectory, but it may not be entirely accurate due to these external factors.
  • DIY Projects
