How to calculate resistance between two electrodes filled with water
To calculate resistance between two electrodes filled with water, the formula R = ρL/A is used, where A is the cross-sectional area and ρ is the resistivity. For a rectangular configuration with a 30 mm gap, the resistivity can be derived from the known conductivity of the solution. In cylindrical geometry, the calculation requires integration over small volume elements to account for the geometry, with the inner and outer diameters specified. Conductivity and resistivity are inverses, so the resistivity can be calculated by taking the reciprocal of the conductivity. Understanding these relationships is crucial for accurate resistance calculations in both geometries.
guptasuryakant
Hello ,
Can someone from this group help me ,how to calculate resistance between two electrodes filled with water with a known conductivity solution.
In my case I have two experimental conditions. First there are two rectangular plates separated with a gap of 30 mm.
In second case this is a cylindrical geometry Innner electrode dia is 10 mm. And outer electrode dia is 50 mm. In between water is filled with a conductivity of 500µ cm/cm.
If some one can answer atleast for one case it will be useful for me.
regards
For the rectangular case, the resistance is
R = \frac{\rho L}{A}
Where A is the crossectional area, and the resistivity is \rho
The calculation is similar for the cylindrical geometry, but you need to set up an integral to do it over small volume elements that approximate the rectangular situation.
How I can put the value in place of resistivity
Thanks for your prompt reply
How I can put the value in place of resistivity in above fourmula
You said you knew the conductivity of the solution. Probably conductivity and resistivity are just inverses, but check the units to be sure.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
