How to Calculate the Flight Time and Apex for a Model Rocket Launch in Excel?
  • Thread starter Thread starter radarspec
    Launch Rocket
The discussion focuses on calculating the flight time and apex of a model rocket using Excel, with specific parameters including a mass of 0.05 kg, an initial force of 16 N, and gravitational acceleration of 9.81 m/s². The calculations are divided into three stages: the first stage involves a thrust phase lasting 0.15 seconds, resulting in a velocity of 46.53 m/s and a height of 10.47 m. The second stage, lasting until 6.15 seconds, requires reevaluation of the velocity due to gravity's downward force, leading to a height of 111.11 m. The discussion highlights the need for clarity in calculating total flight time and apex, emphasizing the correct application of gravitational acceleration.
  • Understanding of Newton's second law of motion (ΣF = ma)
  • Basic knowledge of kinematic equations (v(t) = vo + at, h(t) = ho + vo + 0.5at²)
  • Familiarity with Excel for plotting and calculations
  • Concept of projectile motion and forces acting on an object
  • Learn how to implement kinematic equations in Excel for real-time calculations
  • Research the effects of drag and other forces on model rocket flight
  • Explore advanced Excel functions for data visualization and plotting
  • Study the principles of model rocket design and performance optimization
Students in physics or engineering courses, hobbyists building model rockets, and anyone interested in applying Excel for physics simulations and calculations.
radarspec
A brief explanation, this assignment is to be done in Excel and also has to be turned in with handwritten solutions for finding total flight time and apex. If I can get the handwritten part done Excel is a piece of cake.
A model rocket is launched and I am to evaluate the 3 stages it goes through. During the first 0.15s the rocket (m=0.05 kg) is launched with a force of 16N. It then coasts upward while being slowed done by gravity (g=9.81m/s2. After it reaches apex(max altitude it starts to fall back down. It also deploys a parachute 6 sec. after the motor stops with a constant speed of 10 m/s until it hits ground. Calculate the speed and altitude of the rocket over it's flight time and plot them.
Knowns:
g=9.81m/s2
FE=16N
m=0.05 kg
vo=0m/s
[tex]\Delta[/tex]t=0.01s
Unknowns:
acceleration
velocity
height
total time
[tex]\Sigma[/tex]F=ma
v(t)=vo+at
h(t)=ho+vo+.5at2
Stage 1: 0[tex]\leq[/tex] t [tex]\leq[/tex] 0.15s
use dt=0.01s (was told to do this by teacher for stage 1)
Fe-w=may
ay=[tex]\frac{Fe-w}{m}[/tex]
ay=[tex]\frac{16N-(0.05)(9.81)}{0.05}[/tex]=310.19m/s2
v=vo+at
v=0+(310.19)(0.15)=46.53m/s
h=ho+v0+.5at2
h=.5at2
h=.5(310.19)(0.15)2
h=10.47 m
Stage 2: 0.15 [tex]\leq[/tex] t [tex]\leq[/tex] 6.15s
-w=may
ay=-g
v=vo+at
v=46.53+(9.81)(6.15)=106.86m/s
h=10.47m+(46.53)(6.15)+.5(-9.81)(6.15)2=111.11m
Stage 3: 6.15 [tex]\leq[/tex] t [tex]\leq[/tex] total time
Stage 3 is were I get lost could some point me in the right direction as to find total time and apex.
Your stage 2 is incorrect. At the end of stage 1, you have the rocket's velocity as 46.53 m/s upwards (correct). Then at the end of stage 2, during which the only force is gravity (downward), you have the rocket's velocity as 106.86 m/s upwards. Ask yourself, does this make any sense?
So I would be using -9.81 instead of 9.81 for gravity now? Also would apex be the addition of the height of stage 1 & 2 added together. 111.11 + 10.47 = 121.58m?
Also the velocity and height numbers seem small given the acceleration at lift off.
  • · Replies 22 ·
10K
