How to calculate the force needed to get out of bed?
  • Thread starter Thread starter marciokoko
    Body Force Lift
Calculating the force needed to lift the torso from a horizontal to a vertical position involves understanding torque and lever arms, rather than just applying the basic force equation F=ma. When lifting from a flat surface, the maximum torque occurs when the body is horizontal, requiring consideration of the center of mass and pivot points. If the bed is inclined, the angle affects the torque required but does not change the maximum torque needed to initiate the lift. The discussion also touches on the biological aspects of waking up, suggesting that getting out of bed may feel more difficult in the morning due to perceived changes in gravity. Overall, the calculation of force and torque is complex and varies based on body position and the angle of the bed.
marciokoko
I know from physics 101 that f = ma. And if I want to lift an object straight up i have to multiply its mass times gravity (acceleration) and I get the force I need to require to overcome it.
But what about lifting your body out of bed? Just the part where you physically get up from the lying down position to the sitting up position. In other words, just for lifting your torso up from horizontal to a vertical?
I know it has something to with the the angle but I am not sure how to incorporate it into f=ma.
Thanks
My initial guess is on center of mass. It is a point where all the external forces acting on a body can be considered acting at that point.
Well, initially, center of mass has one position and after the process, it has another which is higher than usual.
So, you need the same force mg to lift you off the bed.
I am not so sure about this treatment.
Your body is not a single point, so giving an answer as a single force value is problematic.
If you model the torso as rigid object that pivots around the hip, you can calculate a force. Initially the whole torso will move directly upwards, which allows to calculate the force as you described. That is not the same as forces inside your body to lift you up, as you have to include lever arms and other issues there.
It might make more sense to calculate the energy required to get out of bed, considering the biological and chemical aspect of waking the **** up.
Likes Gene Schunek
No I am not interested in Energy at all.
Lets imagine that you don't even use the arms. Let's just consider lifting the mass out of bed.
Even if its a rough calculation, how would I go about doing it?
Make a model of what moves where and how the energy changes as function of the position, force (in the direction of motion) is then the derivative of this.
Ok here are my drawings. 4 scenarios.
A: Simplistic F = ma of lifting an object up from the ground.
B: Force at an Angle = Not sure how but if the same object was being lifted up, but at an angle, the force would be different? Like in those examples of a horse pulling a cart vs the same horse pulling that same cart but from a sideroad, at an angle. I kinda remember we needed to consider the angle somehow.
What I really want to understand is the getting out of bed example.
C: Getting up out of bed requires you to lift a weight from 0 angle to 90 degrees (sitting up). This requires a certain force.
D: I want to udnerstand the basic C scenario in order to understand how that would change when inclining the bed, so the person needs to sit up, once again to 90 degrees from the bed, but this time the bed is inclined 20 degrees.
Actually it involves rotating a mass from the horizontal to the vertical position so it requires a torque rather than a force. The torque is at a maximum when the trunk is horizontal (just starting to rotate off the bed.)
Likes russ_watters
Thanks CWatters.
So I ran into this online:
http://hyperphysics.phy-astr.gsu.edu/hbase/torq2.html
Im having trouble understanding what everything is in this diagram. The red line moves thru theta (dunno how to make that on the keyboard of my mac), to where the dotted black line is. I am guessing that's my body.
F is the Force moving that lever. Except that in my case, to that force I will have to add the force of gravity as well, right? because in that diagram I think its considered as being on a flat surface, like twisting a monkey wrench.
How would I enter the values?
According to...
http://www.exrx.net/Kinesiology/Segments.html
Your legs and feet account for about 17% of your mass. Perhaps it would be reasonable to assume that the part being rotated (trunk, head, arms etc) accounts for the other 83%.
Lets say you weigh 100Kg then 83% is about 83kg. If the centre of mass of the moving part is say 0.4m from the pivot point then the required torque is 83 *9.8 * 0.4 = 325Nm.
If you don't like my assumptions you can easily change them.
PS: The above implies something needs to hold your feet down.
No the red line doesn't move through theta. The diagram is showing how to calculate the length of the "lever arm" when it's not at 90 degrees to the applied force.
I'll make a diagram that shows what I meant in post #10. Back soon.
Ok but that website also has a calculator at the end for force, i think.
I did the following, although I like your assumptions better:
I weight 72 kg, so that's = 72 * 9.8 = 705N.
I considered 50% weight in the torso (yours seems more logical), so I went with a rough 350N.
Force Applied 350N
Distance: 1.7m (my height)
Theta: 90 degrees
I got stuck calculating the lever arm. For some reason the online calculator sets my lever arm automaticaly to 1.7m and gives me a value of 595 Nm.
Ok so this shows how to calculate the max torque.
Torque = force * length of lever arm.
As you sit up the length of the lever arm reduces until the centre of mass is over the pivot point. The length of the lever arm and the torque is at a maximum when you are horizontal as shown.
That would imply a pivot point at your feet.
Edit: deleted, think I missed your point. You were referring to the torque being great enough to lift your feet instead of your torso. Agreed.
Yes CWatters, so changing 1,7 to 0.85 I get 297.5Nm.
I know I am leaving out the "someone holding your feet down" counter force and the fact that the lever arm changes.
So but is that correct? I guess it makes sense that you require less force to lift 1/2 your body up to a sitting position that to lift your entire body.
Now I have 2 lingering questions:
A/ If the bed was at an incline, as in scenario D from my image. What would change is the angle, from 90 to 90+20, correct?
B/ If I wanted to consider the changing length of the lever arm as I sit up, I would need to use calculus?
russ_watters said:
Minor issue, but no it doesn't. That's both the torque required to hold your body rigid and horizontal or to rotate at constant speed. The torque to start the rotation is an arbitrarily small amount larger.
Sure. What I meant is... If 83% of your mass is above the pivot point (your hips) then your feet will lift up rather than your head.
marciokoko said:
Yes CWatters, so changing 1,7 to 0.85...
0.85 is on the high side. It should be the distance from the pivot to the centre of mass of the moving part. If the pivot point is at your hips (as in doing sit ups) then I would expect the centre of mass of the top half of you body to be around chest height (hence my estimate of 0.4).
Yes. However since gravity acts vertically the torque will still be at a maximum when the trunk is horizontal. eg raising the legs 20 degrees won't affect the max torque required.
Basic trig might be all you need. For example if you lift up to the 45 degree position the lever arm is 0.4 Cos 45 = 0.28 and the torque falls to 83 * 9.8 * 0.28 = 227 Nm.
Ok I didnt understand either of your answers. I am slow. :-)
A/ I didnt mean raise just the legs. I meant that the entire bed, instead of being flat (0 degrees), the bed is now inclined 20 degrees. Its like making situps in a gym, where you have those boards that you can incline to make the situp workout harder.
How does that factor in? I thought it just meant the torque angle was greater by 20 degrees?
If you had a rope and a pulley, the only force needed would be your weight force - that's eeeaasy! :wink:
Early in the morning it appears to require more force to get out of bed than later in the day, an observation independently confirmed by several people. A possible explanation is a temporal increase in gravity during night/morning, which then is restored to normal level in the day. Hard to calculate.
I expect that caffeine must have certain 'antigravity' properties then. :wink:
I wonder what @OmCheeto has to say about this peculiar effect...
Yes I understood that.
The peak torque required is still the same and it still occurs when the trunk is horizontal (see new diagram).
I agree it is harder to do sit ups that way. That's because now you start with your head lower and have to do work just to get to the horizontal position.
A. I'm no longer allowed to get out of bed like a young person. My physical therapists spent 15 minutes explaining how old people are supposed to get out of bed, to prevent applying excess torque on the lower back.
B. I've doubled my upper body mass, and halved my lower body mass, over the last 366 days, so this problem has no solution, in my case.
C. See below: "Proper method for old people to get out of bed"
But in all seriousness, mfb implied the correct solution in post #3: The force is continuously variable.
Expanded later by CWatter in post #8.
So, IMHO, it is a cantilever problem.
And since "Statics" was the most boring college course ever invented: "The study of things just sitting there", and caused me to fall asleep within the first 5 minutes of class, causing me to fail the class 3 times, at which point I purchased some toothpicks, which allowed me to finally pass the class, allowing me to progress to "Dynamics", which I aced by the way, I would fall asleep if I actually tried to solve this problem.
Proper method for old people to get out of bed:
1. Roll to the edge of the bed.
2. Face the edge of the bed, with your body in a sitting position. Knees, calves, and feet, just at the edge.
3. Prepare your lower arm to lift your torso, as things are going to happen quickly.
4. Move those parts of your body below the knees across the ledge of the bed, which will cause gravity to pull them down, simultaneously pushing with your arm, elevating your torso to a vertical position, thus minimizing torque on your lumbar discs.
5. Get caffeine.
ps.
CWatters said:
According to...
Even though you provided a grand reference, I think you inappropriately used the term "legs and feet", as your reference says they only account for 6.43% of total body mass.
I learned that today, a while back.
OmCheeto said:
Today I learned that we have two kinds of "legs".
Likes Drakkith
Ok so wait. Does it require more force to get out of a 20 degree inclined bed? Why is it harder, actually impossible to do so?
I believe the peak force or torque is the same. It just takes more work.
As has been implied several times before, the torque, and therefore force, change constantly.
This is why I despise wordy solutions to wordy problems. It takes forever to describe, what can be explained with a simple diagram, and an equation.
Torque = Force on the center of gravity on my upper body(constant = 160 lbf) * lever arm length(constant = 1 foot) * cos(θ)
The lever arm length being the distance from my hip joints to my center of gravity.
θ = 0° when laying down
θ = 90° when sitting up
The force you are looking for, to generate the torque, to counterbalance your upper body weight, changes in both magnitude, and direction, as you move.
Given my weight is 160 lb, and my legs are now, a negligible mass:
@ -20°, the cantilever solution for this angle indicates that the Om-extracto-crane attached to my center of gravity is applying 150 lbf.
continuing:
@ 0°: 160 lbf
@ 20°: 150 lbf
@ 40°: 123 lbf
@ 60°: 80 lbf
@ 80°: 27.8 lbf
@ 90°: 0 lbf
So, it is not impossible. It simply requires a crane.
Of course, as you mentioned in your original question: f=ma
So there will be an extra force, at the beginning, to get your butt out of bed.
Very minor, in my case.
This puts me in mind of the Wallace and Grommit film "The Wrong Trousers" in which Wallace's bed tips up and he slides down through the floor into the ground floor and is poured into his trousers on the way. Zero work needed. Just using his GPE from being upstairs.
Likes OmCheeto
Wait, so is it that the force is the same but the work done is greater?
Or is the force greater?
  • #31
Think that was what I said in #24.
The peak torque or force is the same. The work done is greater.
  • #32
Ok and why is the work done greater? Is it simply because the "distance" covered is now 90 degrees + 20 = 110 degrees total?
Or does the inclination or something else have anything to do with it?
IOW, does it take the same amount of work from degree -20 to degree 0 as it does from degree 0 to degree 20?
  • #33
Why do you want to treat this in such an arm waving way? If you tried to treat your finances in this way you would soon end up with no money. It's fairly elementary mechanics and you should just do the proper sums. It's not a matter of 'opinion' and 'the way its put'; it's just a straightforward calculation.
  • #34
Sophie,
If its a straightforward calculation to calculate the difference between getting up from an incline of -20 vs from a 0 degree flat board, then what is that simple calculation? Can you show me?
  • #35
A question that's well formed will often almost answer itself (that's a comment frequently made on PF).
If you draw a diagram of exactly the situation that you are interested in and mark the forces involved, you can use the few basic 'statics' equations (such as the principal of moments and the definition of Work) to tell you what you want.
In the case of getting up out of bed, the model needs to be drastically simplified if you want to get anywhere. Say exactly what the before and after situations are and you can determine the Work done. (mgh would be a start, where h is the height by which your cm is raised).
Whatever you do and to whatever level you want the analysis, you have to specify the problem. Only the questioner can do that (with a bit of guidance, possibly). So start at the very beginning and build ( that means draw, probably) a model to describe the question. . . . . . . . .
  • #36
Ok perhaps I need to clarify. I am not a student, I am a curious person who a few days ago visited a museum where they had a house that was not flat, but rather inclined 20 degrees. So they take you through different rooms to show scenarios of what things change now that the house is inclined 20 degrees. They have a pool table and a table with chairs and the last room is a bedroom. They make you lie down on the bed and try to get up. Of course its impossible to get up from a -20 degree inclined bed.
I asked the guide what would be the physical concept that explained what changes from getting out of a normal bed vs this one with an incline? He was unable to explain it to me. So here I am, a 40 yr old adult who took physics but barely remembers anything anymore. So first let me clarify that I am not being lazy or cheating on my homework :-). I am simply trying to understand (without a high degree of mathematical precision) what changes when getting out of a flat be vs an inclined bed.
Yes of course the first thing I did was make a drawing and I posted it here at the beginning of the thread. The first thing I am trying to understand is simply, "why is it harder to get up out of the inclined bed"? Does the force needed to lift a weight at an angle increase? Or is the force the same but the work required different because that body is being lifted through a greater amount of degrees (-20 -> 90 vs 0 -> 90)? Or what, if anything else, is making it more difficult to get out of the inclined bed?
To be honest I got even more confused thinking that perhaps the force is still the same but the angle makes it more difficult. Then I realized I wasnt really clear about my concepts. So its not so much that I am interested in the exact mathematical calculation. I would like to start by first understanding what is making the "getting up" more difficult.
Thanks
  • #37
marciokoko said:
... Of course its impossible to get up from a -20 degree inclined bed.
Well, I'm not about to build a bed to prove you wrong, so please take a look at the following video, starting at t = 1:10 and ending at t = 1:20.
The guy in video does not look like a super hero, and is able to do a full sit-up from vertical.
So it would appear that the impossibility of getting out of an inclined bed is not based on physics.
My guess is, that you are still not properly describing the problem.
  • #38
Thats because his feet arent moving because they are being held by a strap I guess.
I don't know how you sleep, but I surely don't strap my feet to the bed :-)
  • #39
Sorry, I've been away for a few days..
Yes. In simple terms..
Work = Torque * Angular Displacement
That's the rotational equivalent of the linear..
Work = force * distanceAside: In this case the torque isn't constant so you need slightly more complex maths then this but it should give you the basic idea.
  • #40
The reason that you are still finding it hard to solve this satisfactorily, is that your initial diagram, in fact, doesn't contain all the necessary information. The original question is wide open and can have many different answers. The goal posts in the thread keep changing and it would be better to specify just one particular question, relating to one, fully defined situation and then we / you could come up with an answer.
The trouble with Physics is that (classical Physics, at least) is very formal and has just one answer per situation. It's tiresome for people who 'just want an answer' because it seems to them that people are 'just' being smartness and picky. It really isn't the case (usually on PF, at least). The thread title is very hard to suss out; which Force and where applied - for instance?
  • #41
Ok I'll try to be as clear and singular as possible. My first question is:
What physical phenomena makes it more difficult to get out of a 20 degree inclined bed vs a flat bed. (without your feet being tied or strapped or held)
  • #42
Since E=mc^2, getting out of bed requires the energy from 1 muffin and 2 cups of coffee.
  • #43
You clearly know what you want to be told (or at least, you think you do). What do you actually mean by "get out of"? How do you specify the height of your inclined bed? Is one end raised above the horizontal reference or is the other end lowered? Are you just referring to 'sitting up', so your torso is vertical or are you expecting to stand up too? How are you assessing the 'difficulty' of getting up"? Is it maximum muscular effort or is it just to do with the mechanical work involved? All these questions (and more) need to be answered before you can hope to get an answer to your question. It really isn't that simple.
There are some partial answers that could be arrived at - for instance the work involved in getting your torso horizontal would need to be added to the work in getting from horizontal to vertical. That's just because the cm of your torso is lifted through a greater distance. But, of course, if the mean height of the mass being lifted is different, this will affect the work needed. Are you allowed to use your legs to help you; if you raise them first and then let them drop, you can make getting up 'easier' although the actual work done may be the same.
You need to break down the process into separate actions and specify each one in detail. Earlier in the thread there was discussion about gym equipment. How relevant is all that to your question? I know people with little legs and a massive torso, who could never get up in the way that people seem to be assuming in this thread. They have to roll over and use there arms, along with a lot of grunting. I could sympathise with them if they just stayed there.:wink:
  • #44
It all works by gravity - the gravity of the situation if you don't get up and go to work.
  • #45
Thanks
  • #46
Ok, let me be clearer...
Here are the scenarios I am trying to compare, in order to understand why it was so difficult for me to get out of the inclined bed.
Im only interested in the part of getting out of bed that involves the "sitting up part". The person is lying down on a flat bed, tries to sit up without "pumping" his legs and not having anybody or anything holding his ankles. Specifically this refers to the raising of the torso from flat to vertical = 90 degrees.
Then i would like to compare that with having the same body on a bed which is inclined -20 degrees where the head is dipped lower than the feet.
In comparing those 2 situations I want to understand what makes it more difficult to get up from the inclined bed. At one moment I thought it was simply the fact that the torso was swinging 90=20=110 degrees. But intuition tells me it can't just be that, because if the bed were flat, sitting up the torso from a flat 0 degrees to 90 and then 20 degrees more towards the feet, is not as hard.
Right?
  • #47
Could it be that you're kidding yourself?
You feel it is harder to get sat up from 'head down' than from supine and I'll grant you that it certainly seems to be so when we try it.
But isn't that only because we don't reach a position of 'rest' against the force of gravity until we've moved that extra 20 degrees?
i.e. we just have to move further to get properly 'sat up' - which really means in a position where gravity is acting down along the body, doesn't it? Where we don't need any conscious muscle tension to maintain a comfortable position.
We have to move 110° before we can 'relax' and, in fact, we wouldn't be properly relaxed even then because the body would be slightly imbalanced and gravity still pulling on us. We need muscle tension in the abdomen to retain the position. Try it.
And during the course of that 110° we need to do a greater proportion of the work against the definite hard pull of gravity. Whereas when sitting up from supine we've only got about, what, 70°, of hard work and the last 20° is fairly effortless, the job's done. That's a ratio of 2:7. When starting from head down 20 ° we've got a ratio of 2:110 - and the final position, as I said, is still uncomfortable.
And lastly, sitting up in bed simply isn't as easy as we tend to think. We only do it once a day, mainly, and possibly help ourselves with little twists and manipulations here and there without even realising it. So we think it's easy.
Ask someone to practice a few 'sit up in bed' exercises and you're quickly into something quite strenuous, even to where it can damage people with abdominals in poor shape.
So maybe when it is all considered it simply isn't harder to sit up from head down, it just appears so, but it's really no harder than one would sensibly expect if one were aware of the whole situation.
All the physics gurus here seem to be failing to offer you some factor, some quantity, some formula, that will indicate it is mathematically more difficult to sit up from head down. Something one might vaguely expect perhaps from some vague idea of gravitational effects above or below the horizontal line... Or that's how my vague head vaguely thought of it all...
But maybe that's because there is no such factor, quantity, formula and it is, in mathematics and physics, simply no harder.
The 'more hard' is subjective to the human body and its musculature and to the basic difference in the two tasks - one, in fact, being a greater task than the other as stipulated in the beginning.
  • #48
I think it depends on how you stand up straight from bed. I am considering one usual case. Suppose you are lying on bed. First you would sit up. That will require Torque acting at your pivot point i.e hip bone. Then you will apply torque on your knee joint equal to mg*r. Where m is mass of your body above knee joint and r is length of your bone from hip to knee.
  • #49
I think you will require 2 torques. First to make you sit from liying position in which your hip bone is pivot. Then to stand, knee joint as pivot. I hope that's helpful
  • #50
I thought this might be helpful, a database with measured internal loads in the spine:
http://www.orthoload.com/database/
As "implant" choose "Vertebral body replacement" or "Internal spinal fixation". As activity "from lying to sitting".
