How to calculate the force required for machining a circular tube?
To calculate the force required for machining a circular tube, it's essential to understand that the force varies throughout the machining process and depends on the specific method used. The discussion shifted from a general inquiry about force to a more focused question about the force needed for reducing the outer diameter of a tube from 32mm to 25mm with a wall thickness of 2.3mm. It was clarified that this process is referred to as "reducing," not swaging, and specialized tools are typically employed for this purpose. The exact pressure required for reduction isn't specified, but it's noted that hand or power tools often suffice without needing precise calculations. Ultimately, consulting a handbook or guide specific to the tools used can provide more accurate force requirements.
sagar
Hi everyone,
I need to calculate the force required for machining a circular tube of outer dia 32 and a wall thickness of 2.3, how much ll be the force required for the machining the outer dia to 25?
Welcome to PF;
I suspect you are asking the wrong question - what do you expect the force to tell you?
Basically - there will not be a constant force applied - but different forces in different places at different stages of the machining process - all depending on the specific method used.
If, for instance, you are boring the tube from a cast cylinder, then you will have to apply a torque to turn the bore against the friction of the drill, and you have to apply a force down the axis to press the drill into the metal.
These will depend on the drill properties, and how fast you want to drill the hole out.
Thanks for ur response Simon Bridge,
sorry for the wrong question i asked, actually i need to calculate the force required for the swaging of the circular tube, pls refer this video for reference,
i have only this much following data OD 32 and need to swaged to the OD 25 and it as the wall thickness of 2.3 what is the force required for the swaging to take place? hope now u can able to understand my question
I think I get it now. You are basically deforming the pipe at one end.
OD 32 = outside diameter 32mm - is that correct?
So you want to go from 32mm to 25mm? And the pipe is 2.3mm thick?
1. that's called "reducing" not swaging (iirc - could be wrong)
2. there are specialized tools to do this
3. you'd normally reduce by the thickness... i.e. go from 32mm to 19.7mm
I do not know off hand how much pressure you'd need to reduce pipe for a particular thickness though.
Whenever I've done it, it has always been a power or hand-tool so no need to worry about it.
A handbook with the tool usually has a table or a use guide or something.
This is why I'm wondering what you expect the force value to tell you.
i.e. do you need some value to input into a machine?
Ref:
... that was a large steel tube, and I saw 750psi on the gauge. You'll need less.
Eccentric loads are more trouble to calculate than they are worth. An experienced machinist is a better solution.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
