How to Calculate the Total Mass of Sodium Chloride in Seawater?
  • Thread starter Thread starter elw555
    Chemistry
To calculate the total mass of sodium chloride in seawater, first determine the mass of seawater using its volume and density. The total volume of seawater is 1.5 x 10^21 L, with a density of 1.03 g/mL, which converts to 1.03 kg/L. By multiplying the volume by the density, the mass of seawater is found, and then 3.1 percent of that mass gives the total mass of sodium chloride. It's important to ensure unit conversions are correct, particularly between grams and kilograms. The final result should be expressed in both kilograms and tons for clarity.
elw555
The total volume of seawater is 1.5 10^21 L. Assume that seawater contains 3.1 percent sodium chloride by mass and that its density is 1.03 g/mL. Calculate the total mass of sodium chloride in kilograms and in tons. (1 ton = 2000 lb; 1 lb = 453.6 g)
D=m/v
m=d x v
1.5 x 10^21 x .031= 61324931.65 g/L
61324931.65x .001=61324.93165kg ?
You want mass of seawater first. Use the density of seawater and the volume of seawater to obtain the mass of seawater.
The first step which YOU showed gives the wrong units. Look at the units involved there: Liters x mass/mass
Hi
Your method is right .Only one conversion is wrong 1Kg = 1000g
1L = 1000ml
density =1.03 g/mL = 1.03 Kg /L
you can use it straight here
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
