How to Calculate Work and Power in a Physics Problem Involving Velocity and Time
  • Thread starter Thread starter Cheapo2004
    Work
The discussion revolves around calculating work and power in a physics problem involving a car accelerating from rest to a specified velocity over a given time. The original poster presents a scenario where they need to determine work done and power delivered, but initially lacks distance information.
  • The original poster attempts to derive distance using average velocity and time, then calculates work based on force and distance. They express uncertainty about their calculations and seek verification.
  • Some participants question the appropriateness of the original poster's approach, suggesting a focus on work-energy principles instead of kinematic equations.
  • Others provide alternative methods for calculating acceleration, distance, force, work, and power, emphasizing the importance of consistent assumptions about acceleration.
The discussion includes various attempts to clarify the calculations and approaches to the problem. Some participants offer guidance on using work-energy concepts, while others present their calculations for review. There is no explicit consensus on the correctness of the original poster's work, but several participants engage in checking and validating each other's calculations.
Participants note the importance of assuming constant acceleration and the implications of using different formulas for distance and work. The original poster's initial lack of distance information is a point of concern, as is the need for verification of calculations presented by others.
Cheapo2004
I have a quick question, I need to find Work for this problem, but I don't have a distance!? The problem provides vi and vf, time, and mass, but no distance? How do i find work?
1. A 1.50 X 10^3 kg car accelerates from rest to 10m/s in 3 seconds.
A. What is the work done in this time? W=?
B. What is the power delivered by the engine? P=?
W= Force * Distance (cos theta) <-- Right?
W=? P=? m=1500 kg vi=0m/s vf=10m/s T=3 seconds
******************Edit**************************
I solved my own problem!
x = .5 (vi+vf)time
Anyone want to check my work for me?
W=? P=? m=1500 kg vi=0m/s vf=10m/s T=3 seconds x=?
x= .5 (0+10) 3
x= 15m
Force = mass * acceleration
F = 1500kg * 10...?
F = 15000 J?
W = 15000 * 15
W = 225000 J...?
Thats a lot of work!?
After somebody could nicely check my work i have one more problem...
A skateboard reaches a speed of 35m/s from an initial speed of
25m/s after 21KJ of work
I THINK what the problem is asking for here is: What is the skateboarder's kinetic energy disregarding the mass of the skateboard?
Unfortunately, I don't think your approach was correct. Although, you would have arrived at the same answer (given you had used the correct value for acceleration under the assumption that it is constant), I think it is better you use concepts from Work & Energy rather than mixing in Kinematics unnecessarily.
Firstly, the equation: [d = 0.5(Vf+Vi) x t] only works when the acceleration is constant. There is no reason to assume this from what is given.
Going back to the first principles of work and energy: the work done on an object over a period of time or distance is equal to the change in kinetic energy of that object.
From the question, can you calculate the kinetic energy (0.5mv^2) of the car before the acceleration? And after? What is the difference? By conservation of energy, how much energy should have been delivered?
Power is Energy/time. If that given energy above was delivered in 3 seconds, what is the power?
thats simple
according to ur data,
vi=0 vf=10m/s and t=3secs
u can find acceleration simply by using acceleration formula
a=(vf-vi)/t => a= 10/3 => a= 3.33m/(sec^2)
now putting it in F=m*a where m=mass
F=m*a
now u can find force
about distance u can apply
d= (vi*t) + (a*(t^2))/2
as Force and distance both are in hand
W= F*d and W can be calculated easily
after that P=W/t
so power is also calculated
hope u get the answer correct...
Ok, let's re-do this:
vi=0 vf=10m/s t=3secs m=1500 kg
a=(vf-vi)/t
a=(10)/3
a=3.3m/s^2
d= (0*3) + (3.3(9))/2
d= 14.85m
F = m * a
F = 1500 * 3.3
F = 4950
W = F * d
W = 4950 * 14.85
W = 73507.5 <--- ?
I'd love it for someone to check my latest work :!)
Well
ur work is gr8
  • · Replies 20 ·
