How to Calculate Work Transfer in Steady Flow Conditions
To calculate work transfer in steady flow conditions, the provided formula incorporates kinetic energy, internal energy, pressure-volume work, and heat transfer. The user seeks clarification on the variables, confirming that 'u' represents internal energy, 'v' is velocity, 'p' is pressure, and 'C' is specific volume. The problem involves steam transitioning from high to low pressure, with specific initial and final conditions. The heat loss and steam flow rate are also crucial for determining the rate of work transfer. Accurate application of the formula will yield the desired work transfer rate.
niles_uk
Hi, first post so here goes:
I'm having a little trouble with a question on my tutorial, and I am not sure what to do. Here it is:
Steam under steady flow conditions has the following states:
Initial Conditions:
Pressure - 47 Bar
Spec Volume - 0.09957 m^3 / kg
Internal energy - 3420 kJ/kg
Velocity - 21 m/s
Final Conditions:
Pressure - 10 Bar
Spec Volume - 0.1636 m^3 /kg
Internal Energy - 2440 kJ/kg
Velocity - 38 m/s
Heat is added to the surroundings at the rate of 0.75 kJ/s, if the rate of steam flow is 0.36kg/s calculate the rate of work transfer
I have been given the formula:
(C1^2 /2) + u1 +p1v1 + q =(C2^2 /2) +u2 +p2v2 + w
thanks for any help in advance,
chris
im guessing the
u is internal energy,
v is velocity
p is pressure (in N/m)
c is specific volume?
right/wrong?
****bump****
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
