How to calculate Young's Modulus on trapezoidal shape ? Can't find the answer .
To calculate Young's Modulus for a trapezoidal specimen under compression, the appropriate approach involves determining the average area of the cross-section. The specimen's top area is smaller than the bottom area, leading to the suggestion of using the average of both areas for calculations. The stress can be calculated by dividing the force by this average area, while strain is derived from the initial height and the compression distance. The method involves dividing the trapezoid into horizontal strips, allowing for integration to find the total compression. This approach clarifies that Young's Modulus can be calculated using the average area in relation to strain.
klausner
How to calculate Young's Modulus on trapezoidal shape ? Can't find the answer...
Hi guys.
I'm really stumbling over this question.
If I'm trying to calculate the Young's modulus of a specimen that is being compressed from the top, but the contact area on top is smaller than the bottom area, which area do I use for the cross section ? The smaller area from the top, or the larger area from the bottom ??
Viewed from the side, it would like a trapezoid being compressed from the top, while sitting on a hard surface.
Thanks for your help.
If anyone can recommend a good textbook or article where that is explained, I would greatly appreciate it.
Rick
What do you mean you are trying to calculate young's modulus?
YM is a characteristic property of the material, not the shape.
What are you trying to calculate it from ie what do you know?
I understand the Xsection you have described.
I know the force, the initial vertical height of the sample and the vertical compression distance, and am trying to calculate the Young's modulus, assuming the shape is made up of a homogeneous material.
So I know h and h(0), so I can calculate strain.
But I don't know how to calculate the stress properly. To find the stress, I know force F, but am not sure which area to use (the smaller one on top, or the larger one on the bottom??).
You need to divide your trapezoid into horizontal strips, the width of each will be a linear function of height above the base.
The total load in each strip will be the same so the stress in each strip will be proportional to the width, which in turn will be proportional to the height.
Young's modulus will be the same for each strip.
The compression in each strip will be proportional to the vertical size of the strip, say \deltah
The total compression is obviously the sum of the individual compressions in each strip.
Armed with the above you can allow the vertical size to tend to zero and the sum becomes an integral in terms of height h.
Does this help?
Wow, great.
So is the average elastic modulus equal to the force divided by the AVERAGE area ((A-top + A-bottom) /2) , all divided by the strain?
Since the width of the trapezoid is a linear function of its height, does that mean I can use the average width to get the average area to use in the Elastic modulus calculation??
Thanks so much!
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
