How to Control Speed of One Wheel in a Table Tennis Ball Serving Machine?
To control the speed of one rotor in a table tennis ball serving machine, adjustable-speed drives can be utilized, allowing for independent motor control. The design aims to impart various spins to the ball, enhancing functionality while maintaining a compact structure. Different speeds on the rotors are essential for achieving the desired spin effects. If adjustable-speed drives are not feasible, a pivoting mechanism could be considered as an alternative. Overall, the project focuses on balancing functionality and design for optimal performance.
Cowzer
For my leaving cert project (Ireland) I have to build a table tennis ball serving machine. I'm settling on a design that uses two spinning rotors to fire the ball out as it passes between them, but I'm wondering is there any way to automatically adjust the speed going to one of the rotors (each one will have a different motor)?
Design is like this
http://www.blackwatersports.net/blackwatersportsb2b/images/b2b_Titan.jpg
Is there any way to control the speed of one of the wheels?
Cheers
Is the intent to impart various spins to the ball? If not, I see no reason to have different speeds on the two rotors.
Yeah various spins is the intent as that will increase it's functionality without sacrificing design like a having it on a pivot would make it a bit "clumsy" nearly. There's marks for functionality and design along with other stuff. Is there a way to do it? If not I have a nice way for pivotting it I might use
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
