How to Convert Lead Compensator Output to PWM for Hexacopter Height Control?
  • Thread starter Thread starter huntflex
    Output
The discussion focuses on converting the output of a lead compensator for a hexacopter into PWM format for height control. The user has established a scaling factor of 0.1956 N/PWM, indicating that each PWM input corresponds to a specific thrust in Newtons. They seek clarification on the meaning of 143 PWM, questioning whether it represents a percentage of duty cycle. It is noted that PWM values typically range from 0 to 255 on Arduino boards, where 0 indicates a 0% duty cycle and 255 indicates 100%. Understanding these conversions is crucial for effectively implementing the control system for the hexacopter.
huntflex
Hello, I'm not looking for an answer to my problem, just some hints. Any help would be greatly appreciated.
I am required to control a hexacopter, so I'm designing a lead compensator to control the height, it should be able to counteract the pull of gravity. So far I have designed it, but my problem is that I need its output to be in PWM form.
I already have a scaling which is a= 0.1956 N/PWM, it is also given that a value of 143 PWM will generate hover thrust.(These constants are found from tests on the motor, and are for all 6 motors).
I realize that the feedfwd (see block diagram) should be some value, but I don't know what.
Attached is a snapshot of the block diagram.
Thanks for any help :)
I've long since forgotten my control theory but what does 143PWM mean? What are your units for PWM in a= 0.1956 N/PWM ?
Is it a = 0.1956 Newtons/percent ?
If the pulse width modulation can vary from 0% to 100% how can you have 143%
That is actually a very good question, what I can see from the data that was given to me is that the transfer function for the motor was derived by subjecting it to steps from 150 PWM to 170 PWM, from there a linear regression could be made, and from there it is derived that the slope is a = 0.1956 Newton/PWM. Which means for every PWM sent in, 0.1956 Newton is added to the system.
I just found out, that it's how the Arduino board works, you write 0-255, where 0 is 0% duty cycle, and 255 is 100 % duty cycle
