How to Derive the Velocity Operator in Quantum Mechanics?
The discussion revolves around deriving the velocity operator in quantum mechanics, specifically its relationship with the momentum operator. The original poster expresses confusion about the connection between the velocity operator and the momentum operator, seeking guidance on how to approach the problem and relevant literature.
  • The original poster attempts to understand the derivation of the velocity operator and its relation to the momentum operator, questioning the mathematical steps involved. Other participants suggest applying the operators to the ket vector to explore their effects and clarify the use of the chain rule in the derivation process.
Participants are actively engaging with the problem, with some providing hints and references to sources. The original poster has made progress in understanding the derivation but still seeks clarification on specific mathematical transitions. There is an ongoing exploration of different interpretations and approaches to the problem.
The original poster mentions a preference for scalar simplifications in their inquiry, which may affect the generalization of their questions. Additionally, there is an acknowledgment of the need for further mathematical understanding to complete the derivation.
divB
Hello!
I have a task to do where I do not know where to start or where to find more information.
At first, this is just the problem statement:
Velocity operator [tex]\mathbf{\hat{v}}[/tex] is defined by the following equations:
[tex]\frac{d}{dt} \mathbf{\bar{r}} = \left< \psi | \mathbf{\hat{v}} | \psi \right>[/tex]
[tex]\mathbf{\bar{r}} = \left< \psi | \mathbf{\hat{r}} | \psi \right>[/tex]
where [tex]\mathbf{\hat{r}}[/tex] is the position operator (just the coordinate [tex]\mathbf{r}[/tex] itself). Show that the following relation holds between the operators:
[tex]\mathbf{\hat{v}} = \frac{\mathbf{\hat{p}}}{m}[/tex]
(momentum operator [tex]\mathbf{\hat{p}}[/tex] is given by [tex]\mathbf{\hat{p}} = -i \hbar \nabla[/tex])
I do not understand what the momentum has to do with that. I tried around a while with the integral-definitions of the operators but was not successful. At the moment I have absolutely no idea where to start.
Can anybody give me a hint?
Also some literature which might help me would be greatly appreciated!
Thank you very much and Regards,
divB
Two operators are equal iff they have the same effect on all kets.
Hi,
Thanks for your reply.
Anyway I think I found a source where it is derived:
* http://de.wikibooks.org/wiki/Quantenmechanik#Der_Impulsoperator
But - for sure - I do not really understand the derivation :-( Maybe somebody can help me with that?
First question: Why is
[tex]\frac{d}{dt}\int \psi^* r \psi\,dr = \int \psi^* r \frac{d}{dt}\psi + \psi r \frac{d}{dt}\psi^*\,d r[/tex]
(For the sake of simplicity I take only scalars - I hope this does not harm the generalization)
divB
That's your old buddy, the chain rule...
Hurky is telling you what to do. Try applying the operators to the psi ket vector to show that they give the same result.
Hi,
Thank you very much! I just wanted to write that I got it, really dumb easy :-) Thank you anyway.
About Hurky's hint: Aaah, now understand what he meant. But I think this is exactly what I am doing now: I start with the derivation of the [tex]\mathbf{\hat{r}}[/tex] (as this is v!) and the result should and will be something proportional to p with factor m. Of course this is true if I replace
[tex]-i\hbar\nabla = \mathbf{\hat{p}}[/tex]
in the final equation :-) So I have shown that both are the same.
But I think there is just one piece of mathematics missing for me to understand:
How to come from
[tex]\frac{\hbar}{2mi} \left[-\int d^3r \psi^*(\vec{r},t) \vec{r} \Delta\psi(\vec{r},t)+\psi(\vec{r},t) \vec{r} \Delta\psi^*(\vec{r},t)\right][/tex]
to
[tex]\frac{\hbar}{2mi} \left[-\int \vec{f}\left(\psi^*\vec{r}\vec\nabla\psi-\psi\vec{r}\vec\nabla\psi^*\right) + \int d^3r \left(\vec\nabla\psi^*\vec{r}\right)\vec\nabla\psi - \int d^3r\left(\vec\nabla\psi\vec{r}\right)\vec\nabla\psi^* \right][/tex]
Thank you again,
divB
  • · Replies 0 ·
