The discussion revolves around designing a multistage BJT pre-amplifier that meets specific performance criteria, including gain, input and output impedance, bandwidth, and load conditions. Participants explore various design considerations, rules of thumb, and challenges related to the amplifier's specifications.
- Homework-related
- Technical explanation
- Debate/contested
- One participant outlines the required specifications for the pre-amplifier, including gain between 20-60 dB, input impedance of at least 5K ohm, output impedance of no more than 100 ohm, and a bandwidth of 300Hz to 3MHz.
- Another participant suggests that input impedance can be increased by adding an unbypassed emitter resistor, noting that the effect is amplified by the transistor's hfe.
- There is a discussion about the relationship between gain and the ratio of collector to emitter resistors, with examples provided for calculating gain based on resistor values.
- Participants express uncertainty about the use of the gain-bandwidth product in the design and whether to use average hfe values from the transistor's datasheet.
- Some participants emphasize the importance of stray capacitance in determining bandwidth and suggest using multiple low-gain stages to achieve wider bandwidth.
- There are questions about how to select base resistors and the implications of using gm in the context of BJTs, with differing opinions on its relevance.
- One participant mentions the urgency of the assignment and the challenges faced due to a lack of instructional support from the lecturer.
- Another participant advises on removing certain capacitors to improve gain predictability and bandwidth, while also discussing how to calculate input and output impedances for each stage.
Participants express a range of views on design strategies, with no clear consensus on the best approach to meet the specifications. There are differing opinions on the use of certain design principles and the relevance of specific calculations, indicating ongoing debate and uncertainty.
Participants highlight limitations in their understanding of the design process, including missing assumptions about stray capacitance and the need for specific equations to guide their design efforts. There is also mention of time constraints affecting their ability to learn and apply the necessary concepts.
