How to design a rpm and torque indicator from a fan?
To design a circuit for measuring RPM and torque from a fan, an external detector is necessary for accurate RPM readings. Power can be calculated using the formula Power = Torque * RPM, allowing for torque estimation if power or current is measured at a fixed voltage. Key details about the fan, such as its type, size, power, rated RPM, and application, are crucial for determining the appropriate measurement methods. Options include using strain gauges or a spring balance to measure torque directly, or employing optical devices for RPM measurement. Understanding the fan's motor type is also essential for selecting the right approach to measurement.
dennis12
how to design a circuit to determine the rpm and torque from a fan?
Firstly, welcome to PF.
We need more information. It will be difficult to measure RPM without some form of external detector, but since Power = Torque * RPM, measuring the power, (or the current at a fixed voltage), will make it possible to calculate torque.
What type of fan are you using?
What is it's size and power?
What is it's rated RPM?
What is it used for? Ventilation? or engine cooling?
Is it 12VDC or AC?
Is the fan driven by an induction motor, a universal brush motor or an IC engine?
Another way is to measure the torque that the fan applies to it's mounts. Perhaps mount the fan on an arm that can pivot, use strain gauges or a spring balance etc
You can buy optical devices to measure propeller rpm from model aircraft shops. If the fan uses a brushless motor it might be possible to measure the rpm by tapping off the controller...but if you are able to do that you probably wouldn't be asking the question here.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
