How to estimate a constant drag coefficient of a boat?
The discussion revolves around estimating a constant drag coefficient (Cd) for a prehistoric logboat modeled in MAXSURF, focusing on resistance-performance over a range of speeds. Participants explore theoretical and empirical approaches to determine Cd without having direct measurements of drag force (FD) and velocity (V).
  • Experimental/applied
  • One participant notes the challenge of calculating Cd using the standard formula due to the lack of FD and V, suggesting a need for a workaround.
  • Another participant references an external source that discusses the complexity of drag factors and suggests empirical methods for determining drag coefficients.
  • Some participants emphasize that drag critically depends on the shape and surface roughness of the vessel, which are difficult to express mathematically.
  • One participant proposes using experimental measurements to determine Cd, highlighting that theoretical predictions often have significant errors.
  • Another participant discusses the potential of using video analysis to infer drag from a boat's deceleration after propulsion is removed.
  • There is mention of wave making effects on hydrodynamic drag, which are influenced by hull length and are distinct from viscous drag.
  • A participant questions whether using an approximate Cd would hinder the ability to later infer the actual drag coefficient.
  • Concerns are raised about the tendency for experimental measurements of drag to be larger than theoretical predictions, which could affect the approach to determining Cd.
Participants express a mix of views on the best approach to estimate the drag coefficient, with some advocating for empirical methods while others discuss theoretical limitations. There is no consensus on a singular method or outcome.
Participants acknowledge the limitations of theoretical models and the dependence on empirical data for accurate drag coefficient determination. The discussion highlights the complexity of factors influencing drag, including shape, surface roughness, and wave effects.
This discussion may be of interest to those involved in marine engineering, hydrodynamics, and experimental physics, particularly in the context of boat design and performance analysis.
Panos_leof
TL;DR
Ways to calculate drag coefficient for resistance analysis without knowing drag force and velocity.
Hi there,
I have modeled with MAXSURF a few variations of a prehistoric logboat in order to test a few theories. Now, I am trying to look at resistance-performance over a range of speed. To do so, I need to include a constant drag coefficient without knowing the drag force and velocity (both will be estimated after the resistance analysis).
So, CD = (2*FD)/(ρ*v2*A) is not an option since I am missing FD and V. Also, I cannot solve Cd in terms of the Reynolds number since Re and Cd can relate through velocity.
Is there any other workaround? For now, I just need a constant drag, then I will just use speed^2 and projected area.
Thanks in advance
The drag critically depends on the shape and the surface roughness. Those things are very hard to express mathematically, so the usual approach is empirical.
The timber industry has a long history of pulling logs in the water. The tug boat industry has a long history of pulling barges.
I'll try some searches to see if they have any standard data. Busy today, so give me 72 hours.
Edit: It didn't take as long as I thought. I found this:
https://thenavalarch.com/bollard-pull-calculations-introduction/ said:
If the vessel is a barge, sometimes a simplification is adopted...
Calculation of transverse underwater hull area is pretty simple in case of barges, which generally have a rectangular section shape. If the width of the Barge is B, and its draft is T, then the underwater transverse section area is simply B x T. If there are cuts around the bilge of the barge, these can be deducted from the area. The current force is finally calculated using the standard formula
Current force = ½ x water density x (current speed)2 x underwater transverse section area
Drag coefficients are best determined experimentally.
Most theoretical predictions of drag coefficients have significant errors, often 10% or more.
It's not usually hard to get experimental measurements much better than that.
Of course, you need to have the actual object of interest.
In the case of a real boat, my approach would be to get it to a constant velocity (with propulsion) at the top of the velocity range of interest, remove the propulsion, and get a good video as it slows. Then I would use Tracker to analyze the video and infer the drag from the slowing.
That's spot on. Thanks
That's an interesting approach thanks! Well, I actually have the surface model in a digital form though. So, do you believe that the use of an approximate Cd would not allow me to later infer the actual one?
Thanks for your help guys. I'll try to test a few of the things proposed and integrate them into MAXSURF resistance software. I'll keep you posted for the results.
Effective hydrodynamic drag is strongly dependent on wave making which in turn depends upon hull length. Wave drag is a separate issue from viscous drag.
Infer? How?
Use of an approximate Cd from theoretical considerations does not usually prevent an accurate experimental determination - except perhaps by convincing the relevant parties not to bother with the actual experimental measurements.
My experience is that experimental measurements of drag tend to be larger than theoretical predictions. Those hoping to avoid the "bad news" tend to argue against the usefulness of actual measurements.
9K
  • · Replies 20 ·
