What is the length of a shadow at 8am?
  • Thread starter Thread starter korko
    Angles
To determine the length of a shadow at 8 A.M., one must consider the sun's position in the sky, which changes due to Earth's rotation. At 8 A.M., the sun is two hours past sunrise, meaning it has moved approximately 30 degrees from the horizon, as it covers 180 degrees over 12 hours. The angle of the sun directly influences the length of the shadow cast by objects, such as a 150m building. Understanding the relationship between the sun's angle and the shadow's length is crucial for solving the problem. This approach helps visualize the scenario and apply trigonometric principles effectively.
korko
Hi there!
I need help with trig. I know how to find angles or sides etc. but the problem is I can't picture what this word problem trying to ask me. It would be great if you show me the picture, and I would most likely know how to figure out the sides.
Q1:
On a sunny day, the shadows of stationary objects move slowly across the ground. This is caused by the apparent motion of the sun across the sky, due to the rotation of the Earth. Assume that the sun rises due east at 6a.m, and sets due west at 6p.m.
Find the length of the shadow of a 150m building at:
a) 8A.M
Thanks,
Mathematics news on Phys.org
Look at it in terms of angles and fractions. The sun has 180 degrees to cover over a period of 12 hours. 8am is 2 hours after sunrise. The angle of the sun is related to the angel of the shadow.
Does that help you any?
yes it does, thank you! :D
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
