How to find emission peak of emission spectrum
2 replies · 2K views
Yinxiao Li
Hi all,
I have been getting the emission spectrum of a polymer for a while. The emission peak is very important for that polymer. How do I find the emission peak of the polymer? The reason I ask this question is that if I simply select the highest point, then several points at different wavelengths have very similar counts and there might be some error there...
Yinxiao Li said:
Hi all,
First of all, your question is extremely vague. You did not explain what type of measurement/instrument you were using, and you did not indicate if you have the entire spectrum available.
So why can't you look at the spectrum, select a peak that you want, and pick a point in the middle of the peak? If you have to be more precise with it, fit the peak with a gaussian, if you must, and then use the peak value from your fitting.
Zz.
Zz.
Thanks for your answer. I am using Invia confocal Raman microscope, and the entire spectrum is available. As you have suggested, I should use a gaussian to fit the curve--because I do need an accurate peak. I will try it.
