The discussion revolves around calculating the equilibrium pressures of an equilibrium mixture of N2O4 and NO2 when the volume of the system is doubled at constant temperature. Participants explore concepts related to Le Chatelier's principle, equilibrium constants, and the implications of volume changes on partial pressures.
- Exploratory
- Technical explanation
- Debate/contested
- Mathematical reasoning
- Some participants note that doubling the volume results in halving the pressure and suggest that the equilibrium will shift toward the side with more moles of gas, specifically toward the production of NO2.
- One participant mentions that the equilibrium constant remains unchanged despite changes in volume and pressure, emphasizing that it is dependent only on temperature.
- Another participant expresses confusion about whether partial pressures remain unchanged with volume changes and questions the source of additional particles when the volume increases.
- A participant provides a method to calculate new equilibrium pressures using an ICE table approach, suggesting that the change in pressure for N2O4 and NO2 can be expressed in terms of a variable x.
- There is a query regarding the value of the equilibrium constant (K) used in calculations, specifically whether it is Kp or Kc, and why the initial pressure of NO2 is not included in the equilibrium expression.
Participants express varying levels of understanding regarding the implications of volume changes on equilibrium pressures. There is no consensus on the interpretation of how partial pressures change or the calculation of the equilibrium constant.
Some participants are uncertain about the assumptions underlying the calculations, such as the treatment of equilibrium constants and the relationship between pressure and volume changes. The discussion includes unresolved mathematical steps and differing interpretations of the equilibrium expressions.
This discussion may be useful for students and individuals interested in chemical equilibrium, particularly in understanding the effects of volume changes on equilibrium systems and the application of Le Chatelier's principle.
