How to find mass with gravitational attraction.
The discussion focuses on solving a gravitational attraction problem involving two masses, where the gravitational force is 2.5e-10 N and the distance between the objects is 0.25 meters. The total mass of the two objects is 4.0 kg, with individual masses calculated as m1=3.9 kg and m2=0.1 kg. The key to solving the problem lies in using the gravitational force equation Fg = G m1m2/r^2 and establishing a system of equations to find the individual masses. The participants clarify the process of substituting one equation into another to isolate variables and solve for the unknowns.
  • Understanding of Newton's law of universal gravitation
  • Familiarity with algebraic equations and systems of equations
  • Knowledge of gravitational constant (G = 6.67e-11 N(m/kg)^2)
  • Basic skills in manipulating equations to isolate variables
  • Study the derivation and application of Newton's law of universal gravitation
  • Learn how to solve systems of equations using substitution and elimination methods
  • Explore gravitational force calculations in different contexts, such as planetary motion
  • Practice problems involving gravitational attraction with varying masses and distances
Students studying physics, educators teaching gravitational concepts, and anyone interested in mastering problem-solving techniques related to gravitational attraction and mass calculations.
ssjdbz101
Hello, I'm trying to solve a problem, but I'm doing something wrong.
This is the problem out of my Physics book, but the problem I'm working on has different numbers, so any help will not be cheating, I just need to know the process.
Problem:
Two objects are attracted to each other gravitationally with a force of 2.5e-10 N when they are 0.25 meters apart. Their total mass is 4.0 kg. Find their individual masses.
Answer:
I know the answer is m1=3.9kg, and m2=0.1kg. But I don't know how they got this answer.
Help please.
You can calculate the product of the masses with the given force and distance. Then because you know the sum, you have a system of 2 equations with 2 unknowns
I know that, but I'm still confused.
Since the equation is: Fg = G m1m2/r^2
if I plug in the numbers I'm given:
Fg=2.5e-10
G=6.67e-11
r=0.25
I have: 2.5e-10 = 6.67e-11 m1m2 / 0.25^2.
I solve for m1m2, which is: m1m2 = (Fg*r^2)/G , right?
Doing that, I have m1m2 = (2.5e-10*0.0625)/6.67e-11 = 0.23426
Now what do I do?
I know m1=3.9, and m2=0.1, so shouldn't (m1m2=0.39) ?
The sum of the masses: (m1+m2=4), but how do I use this in the (m1m2=0.39) ?
I'm doing something wrong, but what?
I don't see anything wrong in your calculations but are you sure you copied the numbers right?
If you have two equations: m1 + m2 = 4 and m1*m2 = #
Solve for m1 in one equation like m1 = 4 - m2
And then plug that into the other equation m1*m2 = (4 - m2)*m2 = #
Once you have m2, go back to m1 + m2 = 4 to solve for m1.
The idea is to solve one equation for a variable. Then replace the same variable in the second equation so there's only one unknown.
Thanks, I figured it was that, but for some reason, I could not figure out (4-m2)*m2=#.
Major brain fart.
Thanks a lot!
  • · Replies 28 ·
