How to find the angle from the vertical?
  • Thread starter Thread starter xbabybrittyx
    Angle Vertical
To find the angle from the vertical in this physics problem, the key concept is centripetal acceleration. The force of 40 N acting on the object increases to 47 N when it swings, indicating a change in the effective force due to motion. The formula to calculate the angle involves using the relationship between the tension in the string and the gravitational force. Understanding the dynamics of circular motion will help in deriving the angle. This approach will lead to the solution for the homework question.
xbabybrittyx
I have a question in my homework that I CANNNNOT figure out! it's 40n and feels like 47n when it swings.
i just want to know the formula i would use to figure out the angle.
thanks (:
Welcome to PF!
Hi xbabybrittyx! Welcome to PF! :smile:
(i assume this is a physics problem :wink:)
Hint: centripetal acceleration :smile:
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
