How to find the binding energy of a photon?
To find the binding energy of an electron when an X-ray photon strikes a surface, the initial calculations involved converting the kinetic energy of the emitted electron from eV to joules. The photon energy was also calculated using its wavelength. The confusion arose when attempting to convert the binding energy to kJ/mol, where the user initially overlooked the need to incorporate Avogadro's number. After recognizing this, the correct approach involved converting the energies properly before calculating the binding energy for one mole of electrons. Ultimately, the user successfully solved the problem by making the necessary adjustments.
Mayhem12
An X-ray photon of wavelength 0.940 nm strikes a surface. The emitted electron has a kinetic energy of 947 eV. What is the binding energy of the electron in kJ/mol?
What I did:
(947 eV)(1.602E-19 J)/1 eV = 1.52E-16 J(6.626E-34 J.s)(3.0E8 m/s)/.940 nm (10^-9m/1 nm) = 2.11E-16 J
2.11E-16 J - 1.52E-14 J/1000 KJ/J/1 mol = 5.90E-20 Kj/molObviously, there is something terribly wrong here and my textbook is deemed useless at this point. PLEASE HELP! Thanks
Welcome to PF.
What I did:
You have found the binding energy in kJ for a single electron, not for one mole of electrons.
Okay... so what am I missing? Avagadro's number maybe?
Yes.
I solved it. I had to convert before doing the E-photon and E-released.
