How to find the input output relation of an unknown non-linear system?
To identify the input-output relation of a non-linear system using MATLAB's neural network toolbox, set up a neural network with 10 inputs and 6 outputs, experimenting with the number of layers and nodes for optimal results. Split the 1,000 samples into a training set (approximately 800 samples) and a verification set (about 200 samples) for effective training and testing. While a neural network can predict outputs from inputs, it does not provide a mathematical expression for the relationship, making it a "black box" solution. If the system has no memory properties, the training process is simplified, focusing solely on the current input vector. Alternative methods for deriving an explicit input-output relation beyond neural networks were also requested.
dexterdev
Hi friends,
I have a system (with unknown properties) which takes an input vector of length 10 and outputs a vector with length 6.
I select Inputs vector 'I' which is a 1000x10 matrix, : 1000 samples of 10 elements. And outputs vector 'O' is a 1000x6 matrix,: 1000 samples of 6 elements.
I just want to find input output relation ie system identification.
How can I do this using neural network toolbox in matlab?
-Devanand T
You can try. Depending on what your end goal is a NN may or may not help. In general what you would do is setup a NN with 10 inputs and 6 outputs. The number of intermediate layers and nodes in those layers you would have to play with to find what gives you good results. You would then divide your 1,000 samples into a training and verification set (probably something like 800/200 split) and proceed training/testing it to see if you can find a relation.
The problems you might have:
1.) If in the end you want to be able to write down some mathematical expression for the relation you aren't going to get that from the NN. What you will end up with if it works is a NN that can predict the output from inputs but how it is doing that will be "magic".
2.) If the samples are memory dependent training it will be much more difficult. Does the output vector depend only on the current input vector or do the last X input vectors also have some influence on the output? If the system does have memory you can account for this by also giving the NN the last X input vectors or some of the previous output vectors but the whole thing starts to get more convoluted.
Thanks for the reply first of all... Regarding problem 1) ie an output input relation equation, other than NN can you suggest some method...
And also present output depends only on present input...no memory property for the system.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
