How to Find the Interatomic Distance in Graphite from Electron Diffraction Data?
The discussion revolves around determining the interatomic distance between carbon atoms in graphite using electron diffraction data. Participants explore the application of Bragg's law for interplanar distances and seek methods to derive interatomic distances from experimental measurements, including voltage and diffraction ring diameters.
  • One participant suggests using Bragg's law (2dsin(theta) = n(lamda)) to find the interplanar distance "d" between layers of graphite but questions how to find the interatomic distance "a" between carbon atoms within the same plane.
  • Another participant indicates that determining the interatomic distance requires more than just one diffraction ring and emphasizes the need to calculate the structure-factor based on graphite's symmetry.
  • There is mention of the bond angles in graphite being 120 degrees and an approximate interatomic distance of 0.142 nm, but the participant expresses uncertainty about how to derive this from experimental data alone.
  • A participant notes having two diffraction ring radii but is confused about the significance of having two rings and how they relate to the structure of graphite.
  • Participants discuss the hexagonal structure of graphite and its implications for determining interatomic distances, but clarity on the method remains elusive.
Participants do not reach a consensus on how to derive the interatomic distance from the available experimental data. Multiple viewpoints and methods are proposed, but the discussion remains unresolved.
Limitations include the reliance on specific experimental variables (voltage and diffraction ring diameters) without a clear method for extracting interatomic distances. The discussion also highlights the complexity of graphite's structure and the need for a deeper understanding of its symmetry.
quietrain
ok, i did a lab and found values of the diameter of the electron rings after diffraction from a graphite. i also have the voltage that i accelerate the electrons to hit the graphite.
so to find the distance between adjacent planes of graphite carbon "d", we use bragg's diffraction law right? 2dsin(theta) = n(lamda)
but the problem is what if i need to find the interatomic distance "a" between the carbon atoms on the same plane. is there some sort of equation or law i can use to find this distance from the experiment data that i obtained above? i don't seem to recall any.
and also, am i right to say, the outer diffraction ring is caused by the diffraction between atoms of the same plane (interatomic) whereas the inner diffraction ring is caused by the diffraction between layers of atoms "d" given by bragg's law?
thanks a ton!
maybe i rephrase my question
ok, we use bragg's law to determine the spacing d between LAYERS of graphite
but how do we determine the interatomic spacing A between the individual Carbon atoms for each plane of individual graphite?
anyone knows?
quietrain,
Graphite is pretty simple when it comes to determining the structure-factor. I won't solve the problem for you, but try to represent graphite in terms of a orthorhombic unit-cell with a multi-atom basis. Find the structure-factor based on that symmetry. There is no easy "plug and chug" answer for this problem. Your going to need to do some work!
modey3
er i know the bond angles are 120 and the interatomic distance is around 0.142nm. but how do i get the interatomic distance from an experiment? i only have values for voltage, and the electron ring diffraction diameter only?
so with this 2 variables, i can find the interplanar distance d using bragg's law. but what about the interatomic distance? can i find it from just those 2 variables?
quietrain,
You will need to use more than just one diffraction ring to determine the inter-atomic distance. That's why you need to determine the structure-factor.
modey3
oh ya... i have 2 radius of diffraction rings... one bigger than the other... but i don't understand why there are two?
what is the structure? i only know that graphite is hexagonal in shape, so they have bond angles of 120?
but how does that allow me to find the interatomic distance?
  • · Replies 0 ·
