How to Find the Maximum Range of a Ball Shot from a Spring Gun?
  • Thread starter Thread starter vipulgoyal
    Energy Power Work
To find the maximum range of a ball shot from a spring gun, start by calculating the velocity using the equation 1/2 kx^2 = 1/2 mv^2, where k is the spring constant and x is the compression distance. After determining the velocity, apply projectile motion equations to find the time of flight. The horizontal range can then be calculated using the formula distance = velocity x time of flight. It's important to note that gravitational force (F = mg) does not directly apply to finding the range in this context. This method provides a systematic approach to solving the problem effectively.
vipulgoyal
a 15 g ball is shot from a spring gun whose spring has a force constant600 N/m the spring is compressed by 5cm the greatest posible horizontal range of the ball for this compression is
what equation should i use to find the distance i know the enrgy stored
i used i/2 k x2 = F.s
then put F = mg the answer doesn't come
Hello Vipul. you are mistaken. F = mg is gravitational force, which is not the acting force for the required answer.
use 1/2 kx^2 = 1/2mv^2 and find velocity. then use equations of projectile motion, find time of flight(t), and v.t = distance.
