How to find torque of rotational friction on an axle?
The discussion revolves around calculating the torque of rotational friction on an axle in the context of programming a physics engine. Participants explore the implications of friction in a pendulum-like system and seek to understand how to model this effect accurately.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • One participant describes their attempt to simulate a pendulum and the need to incorporate friction to avoid perpetual motion, expressing uncertainty about how to calculate the opposing torque due to friction.
  • Another participant suggests that the simplest model for retarding torque is proportional to the tightness of the axle fit, while a more complex model relates it to angular velocity.
  • A participant attempts to draw parallels between translational and rotational friction, expressing confusion about how to define "normal torque" and its implications for the system's dynamics.
  • Discussion includes the mechanics of dry versus lubricated bearings, noting that the friction torque can be derived from the tangential friction force and the radius of the pivot pin.
  • One participant raises concerns about the behavior of the system if friction is not properly accounted for, questioning the logic of simply subtracting friction from external torque.
  • A suggestion is made to use a free body diagram to clarify the forces acting on the pendulum arm.
Participants express various models and approaches to understanding rotational friction, but there is no consensus on the best method or the specific calculations required. The discussion remains unresolved with multiple competing views on how to accurately model the frictional effects.
Participants acknowledge limitations in their understanding of how normal forces and friction interact in a rotational context, and there are unresolved questions about the implications of these forces on the motion of the pendulum system.
CK_KoopaTroopa
Hi, I'm trying to program a simple physics engine from scratch as an exercise, and I'm starting with manipulating a stick with the mouse pointer. As of now, it dangles from one end demonstrating simple pendulum physics. Now, I want to add a friction component to the "axle" it's rotating on to avoid perpetual motion, like when you put a pencil through the end of a ruler and swing it back and forth.
I can create this illusion by making a line that says "omega = omega * 0.9" (omega being angular velocity) each frame, because right now I'm bypassing torque altogether and skipping straight to acceleration (which I realized this morning was a terrible idea... I know how to fix this though).
However, even though that appears right when I run the program, it doesn't seem to line up with real-life physics at all. What I need is a torque that goes against the torque of gravity (-m*g*L*sin (theta)); I just don't know how to find what that torque is. I'm pretty sure there's one equation I'm looking for, but I forget how friction works mathematically and I can't find it online or in my high school physics notes for the life of me! Anyone got it?
The simplest model just has the retarding torque proportional to how tight the turning section fits the axle.
The next most complicated has the retarding torque proportional to the angular velocity.
I'd use the first one for the case of a ruler swinging on a pencil ... the "tightness" is the normal force at the contact point. The second works better for larger systems, and where there are bearings, lube, and so on. Also see:
https://au.mathworks.com/help/physm...iction.html?requestedDomain=www.mathworks.com
http://lpsa.swarthmore.edu/Systems/MechRotating/RotMechSysElem.html
http://www.mogi.bme.hu/TAMOP/robot_applications/ch07.html
Thanks for the response! The links you provided certainly do have a lot of information, but maybe too much! If I have to go through it all I will, but I feel like this is a lot simpler... I was thinking along the same lines of getting the tightness at the contact point, and originally tried to just think up the analog for rotational friction from translational (which, if I remember right, is Fnet = Fexternal + Ffriction for Fexternal = ma and Ffriction = -μFnormal) which would go to τnet = τexternal + τfriction for τexternal = Iα and τfriction = -μτnormal but I can't figure out what the "normal torque" (?) would be for that joint.
Come to think of it, I forget how regular normal force works... Because I remember it's just Fnormal = mg sinθ, but if that was the case, let's say Fexternal = 0 then Fnet would just be -μmg sinθ, meaning it would decelerate past 0 and accelerate in the other direction! That can't be right...?
In a dry bearing the pivot pin only touches the bearing over a relatively small area . The normal force on that area and the coefficient of friction give you the tangential friction force . Force times radius of pivot pin gives you the friction torque .
The mechanics of what happens in a dry bearing can be more complex than this in reality but the simple calculation is what is commonly used and gives reasonably accurate results .
In a lubricated bearing friction torque is mainly due to viscous drag effects . Can be estimated theoretically but calculations are not easy for real bearing systems .
Retarding torque on pendulum arm may in any case be due to air resistance as well as pivot friction .
Ahh, ok. The tangential friction force times radius makes perfect sense, but now how do I apply that? I can't simply subtract it from the external torque, because unless I'm doing something wrong that would make it continue to accelerate in the opposite direction even after decelerating to a complete stop.
Friction only acts to oppose motion .
Try drawing a free body diagram for the pendulum arm .
  • · Replies 19 ·
  • · Replies 32 ·
  • · Replies 16 ·
  • · Replies 60 ·
  • · Replies 22 ·
