How to induce current on a static conducting material?
The discussion centers around the concept of inducing current in a static conducting material using a magnetic field. Participants explore the principles of electromagnetic induction, the necessity of changing magnetic flux, and potential methods for achieving this without moving the conductor itself.
  • One participant suggests that inducing current requires a change in magnetic flux, implying that movement of magnets is necessary.
  • Another participant questions the purpose of inducing current and expresses uncertainty about whether a current is needed at all.
  • There is a query about the mechanics of moving magnets, including whether to move one or both magnets and the nature of the movement (e.g., left to right).
  • Participants inquire about equations to calculate the required magnetic strength for a given distance and how to create a magnetic field with variable strength.
  • A suggestion is made to watch a video on electromagnetic induction for further understanding, along with the idea of moving the conductor through the magnetic field or rotating it to induce current.
  • One participant provides a formula for calculating magnetic flux as a function of time, linking it to voltage through the time derivative.
Participants generally agree that a change in magnetic flux is necessary to induce current, but there is no consensus on the specific methods to achieve this or the necessity of inducing current in the first place. Multiple competing views and uncertainties remain regarding the setup and approach.
Limitations include unclear assumptions about the setup, the dependence on definitions of magnetic flux and strength, and unresolved questions about the practical implementation of the discussed methods.
Individuals interested in electromagnetic induction, experimental physics, and those seeking to understand the principles of inducing current in conducting materials may find this discussion relevant.
Jay_zero
Dear Physicists,
I am currently thinking of a way of inducing a current in a conducting material by a magnetic field. I am not good at magnetism and electricity at all, but I think it should look like the picture below. By the way, the material in the middle does not move.
Does anyone think that this setup will help induce a current in the material? if not how should I do it. By the way, is it possible to change the strength of the magnets at all? Please guide me in the correct direction as I am very lost here and don't know where to look. Suggestions are much appreciated on what field to look at. Thank you everyone.
You need a change in magnetic flux to induce current . So you will have to move those magnets some how . What is your purpose for inducing current .
It is not used to power up anything electrical at all. However, I think it is silly to say that I don't even know if I really need a current in the material at all. Anyway, so I need to move the magnets? like left to right and back again? Do I have to move both magnets or one magnet? However, are there any equations to calculate how much magnetic strength I need for a given distance? And last question, how to create a magnetic field with variable strength?
Thanks again.
Watch the first 20 minutes of this video and he talks about electromagnetic induction and it might help you and it is a very good video.
Or you can move the conductor through the B field to induce current , Maybe you could have it rotating or something.
And if you have it rotating and you know the angular frequency, And you know the field strength , then you can calculate the magnetic flux as a function of time .
Using Flux=Acos(bt) where a is the cross-sectional area and b is the angular frequency
and the time derivative of this will be voltage .
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 25 ·
