How to integrate int (x^2 + 4)^(-1/2) dx Is it a substitution?
To integrate (x^2 + 4)^(-1/2) dx, a trigonometric substitution is recommended, utilizing a right triangle where the hypotenuse is the radical and one side is 2. By letting u = x^2 + 4, the differential du can be expressed as du = 2x dx, leading to dx = du/(2x). Substituting these values simplifies the integral to (1/2) ∫ u^(-1/2) du, which results in (x^2 + 4)^(3/2) + C after integration. This method effectively resolves the integration challenge presented.
gordda
I need help antidiffing this equation:
(x^2+4)^(-1/2)
i have tried subbing u=x^2+4 i have tried subbing u= (x^2+4)^(-1/2).
i have tried making x the subject. even tried to use partial fraction, with no avail, because i could not figure out how to use partially factorize it.
If anyone could lead me towards the right answer.
Thanks.
(x^2+4)^(-1/2)
Thanks.
Whenever you have an integrand that looks like the Pathagoras theorem, use trig substitutions. You know, draw a right triangle with theta in it. Then the hypotneuse is the radical, one side is 2, the other is x right. Follow through: What would the tan(theta) be?
Yes, integrating (x^2+4)^(-1/2) can be done using substitution. Here's how:
Let u = x^2 + 4
Then du/dx = 2x
And dx = du/2x
Substituting these values into the original equation, we get:
∫ (x^2+4)^(-1/2) dx = ∫ (x^2+4)^(-1/2) * (du/2x)
= (1/2) * ∫ u^(-1/2) du
= (1/2) * ∫ u^(-1/2) * u^0 du
= (1/2) * ∫ u^(1/2) du
= (1/2) * (2u^(3/2)) + C
= u^(3/2) + C
= (x^2+4)^(3/2) + C
So, the final integrated form is (x^2+4)^(3/2) + C. You can also verify this solution by differentiating it and checking if it gives the original equation.
Hope this helps!
