How to know the level of a tank by displacing the liquid
  • Context: Undergrad
  • Thread starter Thread starter Fernando Franco
    Liquid Pressure Tank
The discussion revolves around determining the liquid level in a tank using a bubbler level gauge system, which measures the pressure required to displace the liquid. Participants explore the relationship between pressure readings and liquid level, considering known parameters such as tank height, diameter, density of the liquid, and tank volume.
  • Exploratory, Technical explanation, Homework-related
  • One participant describes a scenario involving a differential pressure sensor to measure the pressure needed to displace liquid in a tank and seeks a formula to relate this pressure to the liquid level.
  • Another participant inquires about Pascal's law, suggesting it may be relevant to the problem.
  • A subsequent reply indicates a lack of familiarity with Pascal's law and requests a specific formula.
  • Another participant emphasizes the importance of self-research and encourages looking up information rather than seeking direct answers, referencing the community's educational ethos.
The discussion does not reach a consensus on the specific formula or method to determine the tank level from the pressure readings. Multiple viewpoints exist regarding the application of Pascal's law and the approach to finding a solution.
Participants have not provided specific formulas or detailed explanations of how to apply Pascal's law to the problem. There may be assumptions regarding the ideal behavior of the liquid and the sensor that are not explicitly stated.
Fernando Franco
Hi friends,
I have the following problem, I know there is a system named bubbler level gauge, it works by measuring the required pressure to displace the liquid inside a tank.
My known data is:
the height of the tank
The Diamater
The Density of the liquid
The Volume of the tank
Let's say I place a differential pressure sensor and I read the required pressure to displace the liquid, how can I know the level of the tank ? there must be a formula to determine when the tank is full, or 50%, knowing the pressure required to displace the water
(please take a look at the following image)
Are you familiar with Pascal's law?
Not much, do you have a formula my friend?
  • · Replies 26 ·
  • · Replies 33 ·
  • · Replies 139 ·
53K
  • · Replies 109 ·
9K
9K
