How to Manipulate Lim Sups and Lim Infs in Proofs?
  • Thread starter Thread starter cmurphy
Understanding lim sups and lim infs is crucial for proving properties of bounded sequences. The discussion highlights the need for clarity in manipulating these concepts, particularly in proofs involving sums and products of sequences. A key point is that for bounded sequences, the limit superior of their sum is less than or equal to the sum of their limit superiors. Similarly, the limit superior of their product is bounded by the product of their limit superiors. The conversation emphasizes the importance of grasping the definitions and applying them effectively in proofs.
cmurphy
Hello,
I have several questions regarding lim sups and lim infs. I have a couple of proofs that I need to do, and I'm not sure where to start, because I don't have a good understanding of how to "play" with the definition; lim sup sn = lim N -> infinity sup{sn: n > N}.
Any suggestions?
An example of a problem I'm struggling with is:
Show that lim sup(sn + tn) is less than or equal to lim sup sn + lim sup tn for bounded sequences (sn) and (tn).
Similarly, how could I show that lim sup(sntn) is less than or equal to (lim sup sn)(lim sup tn), where (sn) and (tn) are bounded sequences of nonnegative integers?
Thanks in advance,
Colleen
For any e, there is an N so that sn<=e+limsupsn and tn<=e+limsuptn, for all n>=N. Therefore sn+tn<=limsupsn+limsuptn+2e for all n>=N. I'm sure you can finish it. The same trick can be used for the product limsup.
I understand what you've done, but I don't actually see how to proceed. Since
sn + tn - 2e <= lim sup sn + lim sup tn, how do you get lim sup (sn + tn)? I think this might go back to the problem that I'm having with understanding how to manipulate lim sup. Conceptually, I understand what it means, but in terms of manipulating this for a proof, I get lost.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
