How to prepare 500 mL of 0.025 M of Glucose solution?
  • Thread starter Thread starter science_rules
    Glucose Prepare
The discussion revolves around the preparation of a 500 mL solution of 0.025 M glucose by diluting a 1 M glucose solution. Participants explore the calculations and methods involved in achieving the desired concentration through dilution.
  • Homework-related
  • One participant expresses uncertainty about how to prepare the solution and whether to divide 500 by 1000 mL first.
  • Another participant calculates the number of moles in 500 mL of a 0.025 M solution, arriving at 0.0125 moles.
  • Several participants confirm the calculation of how many mL of a 1 M solution would contain that number of moles, suggesting it is 12.5 mL.
  • One participant introduces the formula M1V1 = M2V2 as a method to simplify the calculation for dilution.
  • Another participant mentions the concept of "fold dilution," stating that a 40-fold dilution is required to prepare the solution.
There is general agreement on the calculations leading to the conclusion that 12.5 mL of the 1 M glucose solution is needed, but the discussion includes varying levels of understanding and approaches to the problem.
Some participants demonstrate uncertainty in their calculations and the steps necessary to achieve the final volume, indicating a need for clarity in the dilution process.
science_rules
I am using a virtual chemistry laboratory and the directions for the first lab experiment says to prepare 500 mL of 0.025 M of glucose solution by diluting the 1 M glucose solution. (I am re-posting this question due to the fact that the previous one was deleted because it wasn't placed in the appropriate forum.) [/B]
Prepare: 500 mL of 0.025 M of glucose solution by diluting the 1 M(1 Mole) of glucose solution with distilled water.[/B]
I am not sure what to do here and I don't know what I am supposed to multiply. I tried adding the diluted water to it, but it said that it would overflow because I had added 400 mL of the diluted water. It said to indicate in the report, which solutions were mixed together and the amounts of each, but I am not sure how to mix them. I take it the M stands for Moles? And mL stands for mililiters. Do I divide 500 by 1000mL first? [/B]
How many moles of glucose are in 500 mL of a 0.025 M solution of glucose?
How many mL of a 1 M solution of glucose contains that number of moles of glucose?
Ygggdrasil said:
How many moles of glucose are in 500 mL of a 0.025 M solution of glucose? 500/1000 X 0.025 moles = 0.025 moles of glucose?
0.0125 X 1000 = 12.5 mL?
answer to your first question 1) 500/1000 X 0.025 moles of solution = 0.0125 moles?
answer to your second question 2) 0.0125 X 1000 = 12.5 mL?
Correct. To make 500 mL of a 0.025 M solution of glucose, you would take 12.5 mL of a 1 M solution of glucose, and add water to that until the final volume is 500 mL.
An easier way remember this approach is the formula M1V1 = M2V2.
In this case, the calculation would be 1M * V1 = 0.025M * 500mL. If you solve for V1 you would get 12.5 mL (essentially the same calculations as you presented above, just placed into one single formula).
Alternatively, you can calculate the "fold dilution." 1 M / 0.025 M = 40, so you are performing a 40-fold dilution. That means you would take 500 mL/40 = 12.5 mL of 1M glucose and dilute to 500 mL.
Thank you!
  • · Replies 19 ·
