How to produce a standing wave question
  • Thread starter Thread starter michaelraymen
    Standing wave Wave
A standing wave can be produced on a wire of length 1 meter if the wavelength is an integer fraction of the length. For wavelengths of 30 cm, 1 m, and 75 cm, standing waves can be formed because they fit into the wire as integer multiples of half wavelengths. However, a wavelength of 2 m cannot produce a standing wave since it exceeds the wire's length and does not fit as an integer multiple. The fundamental mode requires that the length of the wire accommodates a whole number of half wavelengths. Visualizing or sketching the scenarios can aid in understanding the conditions for standing wave formation.
michaelraymen
using a wire of length L= 1 M with both ends fixed, can you produce a standing wave with the following wavelengths? Explain why or why no.
a. 30 cm:
b. 1m :
c. 75 cm :
d. 2 m :
L=n. (λn/2)
1m= n. 30 cm/2 ?
A standing wave must fit a full "wave" inside the given length. In other words the length must be an integer multiple of the wavelength.
So would all of the wave lengths work except for the 2 meter one?And How can I explain it with the formula?
Thank you for your help.
a. 30 cm:
b. 1m :
c. 75 cm :
d. 2 m :
L=n. (λn/2)
1m= n. 30 cm/2 ?
For a string or wire fixed at both ends, the fundamental mode fits a half wavelength between the nodes, no?
Welcome to the PF.
I'd suggesting sketching each of the possible answers, to see if you get a whole number of half wavelengths between the nodes.
