How to prove that the derivative f this function is |x|
  • Thread starter Thread starter transgalactic
    Derivative Function
transgalactic
how to prove that the derivative of this expression
<br /> f(x)=-\frac12x^2,x&lt;0<br />
<br /> f(x)=\frac12x^2,x&gt;=0 <br />
is f'(x)=|x|
i tried
<br /> \lim _{x-&gt;0^-}\frac{f(x)-f(0)}{x}=\lim _{x-&gt;0^-}\frac{-\frac12x^2-0}{x}=\lim _{x-&gt;0^-}-\frac12x=0\\<br />
<br /> \lim _{x-&gt;0^-}\frac{f(x)-f(0)}{x}=\lim _{x-&gt;0^-}\frac{+\frac12x^2-0}{x}=\lim _{x-&gt;0^+}+\frac12x=0<br />
but i get values
it doesn't show that f'(x)=|x|
You calculated f'(0) and found that it is 0. So this doesn't contradict f'(x) = |x|. Now calculate the derivative for all other x as well :-p
<br /> \lim _{h-&gt;0^-}\frac{f(x+h)-f(x)}{h}=\lim _{h-&gt;0^-}\frac{-\frac12(x+h)^2+\frac12x^2}{h}=\lim _{h-&gt;0^-}\frac{-\frac12(x^2+2xh+h^2)+\frac12x^2}{h}=\lim _{h-&gt;0^-}\frac{-\frac12(2x+h)}{1}=-x\\<br />
<br /> \lim _{h-&gt;0^+}\frac{f(x+h)-f(x)}{h}=\lim _{h-&gt;0^+}\frac{\frac12(x+h)^2-\frac12x^2}{h}=\lim _{h-&gt;0^+}\frac{\frac12(2xh+h^2)}{h}=\lim _{h-&gt;0^+}\frac{+\frac12(2x+h)}{1}=x\\<br />
what to write in order to finish this prove??
Almost... you didn't mean to write h \to 0^\pm under the limits, because both limits are two-sided. So, the first one is just
<br /> \lim _{h\to0}\frac{f(x+h)-f(x)}{h}=\lim _{h\to0}\frac{-\frac12(x+h)^2+\frac12x^2}{h}=\lim _{h\to0}\frac{-\frac12(x^2+2xh+h^2)+\frac12x^2}{h}=\lim _{h\to0}\frac{-\frac12(2x+h)}{1}=-x\\<br />
You probably meant to say, that the top line is for x < 0 and the bottom line is for x > 0 (because on the top line you are using the part of the definition for x < 0 and on the bottom line you are using the definition of f for x >= 0).
So now you have shown that f' exists everywhere and is equal to
f&#039;(x) = \begin{cases} -x &amp; \text{ if } x &lt; 0 \\ 0 &amp; \text{ if } x = 0 \\ x &amp; \text{ if } x &gt; 0 \end{cases}
Can you conclude now that f'(x) = |x| ?
can I ?
You should know. Compare his expression for f&#039;(x) with the definition of |x|.
transgalactic said:
can I ?
Look at robueler's post concerning y(x) = |x|.
