How to slow down the charge & discharge process in RC battery
To slow down the charge and discharge process in an RC circuit, increasing resistance and capacitance is essential, as both factors extend the time constant. A larger resistor will slow the charging and discharging rates, but may result in minimal current flow. Adding capacitors in parallel can also help, but the effect may be limited if not optimized. It's recommended to calculate the appropriate RC time constant rather than relying solely on trial and error. Understanding these principles will lead to more effective control over the charging process.
Ikaa
I am trying hard to figure it out how to slow down the charge and discharge current in the RC circuit. If i put the big resistor, it takes long to charge but there is barely any current you can see and also when it discharges. What I am trying to do is, to slow down the charging time, so I can see voltage charge slow and also with nice charge of current. So far, I have tried to put lots of capaciter together in parellal, so it takes longer to charge but seems like it has very little effect. I am using labjack U12 to display current in labview. Please help me if you can
From what you have done so far you have already solved the problem and you just need to tidy it up and finish it off.Look more carefully at what you have already discovered.
1.The bigger the resistance(R) the longer the time.
2.The bigger the capacitance(C)the longer the time.
It boils down to finding a suitable value for RC.Rather than trying it by trial and error try googling "capacitor time constant" and work it out.
Thanks Dadface for your kind input...
Ikaa
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
