How to take fire flow conditions into account ?
In designing a water distribution network for a residential area, the challenge lies in optimizing fire flow conditions without overdesigning the system. Each fire hydrant must supply 15 liters per second, but only one hydrant will be used at a time in any area. The current approach of assigning a fixed flow to each hydrant leads to unnecessary overcapacity. A more efficient method involves optimizing the network under normal conditions and then individually testing each hydrant's flow requirement while monitoring node pressures. This strategy balances the need for adequate fire flow with the realities of system demand.
EngineeringDaN
For a project in my 3rd year hydraulics course we have to design a water distribution network for a residential area using EPANET and optimizing it using GAWUP (GANEO).
I have the entire network set up with all the peak flow demands set for each of the required nodes. Using GANEO I can easily optimize this system to give me the best combination of pipe diameters to meet the required pressures and flows at each node. However, I am not sure how I would optimize the system for cases of fire flow. Any fire hydrant in the network at any given time must be able to supply 15 litres/sec in case of a fire, and not more than one fire hydrant must be used in any specific area. I cannot just assign a flow of 15 litres/sec to each fire hydrant and then optimize the system in GANEO. While this would assure I would get the required flow at any fire hydrant at any time, the system would be highly over designed because in reality you would never need more than one fire hydrant open in any specific area.
How can I optimize the network so that any specific hydrant in the system has the required demand of 15 l/s without fixing a flow of 15 l/s to every single fire hydrant ?
Note: This is a rather large network with one reservoir supplying about 180 different nodes and about 50 fire hydrants in total. It would be impossible to analyze the system for different demand flow scenarios without a computer.
The obvious (albeit long) way is to optimize the system under normal conditions, then assign each hydrant, one by one, the 15 l/s flow and check the pressures at your nodes, upsize system as necessary.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
