How to tell if an object is moving
  • Thread starter Thread starter Yoghurt114
Determining if an object is moving in space requires a reference point, as there is no absolute frame of reference. Observers can assess movement relative to distant objects using parallax or by detecting Doppler shifts in light emitted from the object. The Doppler effect applies not only to sound waves but also to electromagnetic waves, such as light from stars or planets. If no Doppler shift is detected, it may suggest the object is not moving relative to the observer, but this is only true from that specific frame of reference. Ultimately, movement is always relative, and different observers may perceive the same object's motion differently based on their own frames of reference.
Yoghurt114
Simple question, to which I have no answer.
Say, you encounter an object in space. How can you tell if it's moving, if you don't know your own location or speed, and you don't have anything you can use to navigate by or determine your location.
Asked out of pure interest.
Thanks.
You cannot. First it is critical to understand that there is no absolute frame of reference, that is, you cannot simply say an object is "moving", but you must specify what is it moving relative to. If you'd like to know if an object is moving relative to you, well then that's quite simple. One way is to look at its parallax, i.e. is its position changing relative to some very distant objects (stars or quasars or something like that). Another way would perhaps be to look for any kind of doppler shift coming from any light emitted from the object.
The doppler shift is the answer I was looking for. Thanks.
I was under the assumption the doppler shift only applies to ambulances and police cars ;>
Never realized it also applies to electromagnetic waves, but it of course makes perfect sense.
Doppler shift on incoming light if the object is something like a star or planet or nebula and very far away. If it is something like a spaceship at close range, then normal radar or a laser range finder would work. And at a close enough distance you could see it moving relative to you.
By the way. If the object does not seem to have any doppler shift of EM waves in any direction. Wouldn't it be safe to assume it is not moving? That is. It is not moving relative to ... space?
The object would only have no doppler shift from YOUR frame. I could be in another frame traveling away from it and it would have doppler shift for me. There is NOT a frame for space itself. The closest thing you could say would be to take a frame of the cosmic microwave background.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
