How to work out this Acceleration
  • Thread starter Thread starter koyabr
    Acceleration Work
The discussion revolves around calculating the acceleration of a cubic slider on a ramp, with no friction considered. The user is struggling to understand the forces at play, particularly the net horizontal force on both the block and the ramp. They reference Newton's 3rd Law and the conservation of momentum to approach the problem but are confused about the resultant force's direction and size. Despite attempts to use vector analysis, their calculated answer differs from the expected result. The user plans to consult the question provider for clarification on the discrepancy.
koyabr
I`ve posted relevant picture.No thought for any friction.The ramp`s mass is M,and the cubic slider`s is m.Release the slider(no initial speed),What`s the Acceleration(relative to the earth) of it?
I`ve been told the answer,as is showed in the picture.But I can`t work out it for myself.
I got stuck when I`ve brought in too many parameters,I might have mistaken something.
I`m a new comer and English beginner,hope I`ve described the question clearly.Thanks for viewing.:)
Remember Newton's 3rd Law of Motion, for every action there is an equal and opposite reaction, meaning:
Think about this given situation at a stand-still, where the block is on the ramp at the top but nothing moves (because everything is starting from rest). There is no motion, correct?
Gravity then pulls the block down the ramp, which then causes the ramp to move as well (remember, everything started from rest, aka net F=0 initially). If the intial net F=0, then the final net F must equal 0 as well, agreed? With the understanding of the fact that momentum is conserved, you must solve for the net horizontal force on the block (horizontal to the ground surface that the ramp is not, not horizontal to the ramp itself). This must also equal the net horiziontal force on the ramp caused by the block. Setting these two equal should be your method of solving for a.
Thank EngineerHead and I think I`v figured out the process,the most disturbing thing is the resultant force of the block,whose direction & size are not so clear.I tried the vector triangle,and found the sine theorem useful in working out the resultant force`s size.
Astonishing enough,I got a different answer from what`s showed in the picture,perhaps I have to consult the question provider.
