How train is travelling through a curve?
  • Thread starter Thread starter aneeshk
    Curve Train
When a train navigates a curve, the wheels on both sides rotate at the same speed, but the inner rail has a smaller curvature than the outer rail. This means the outer wheel must cover a longer distance than the inner wheel. The phenomenon occurs because the inner wheels can slip on the rail, allowing for this difference in distance without requiring banking of the track. The discussion highlights the mechanics of wheel rotation and rail interaction during curved travel. Understanding this concept is crucial for grasping train dynamics in curved sections of track.
aneeshk
Hello,
Please help me to find out the answer for the following question...!
When a train is running, wheels at both sides are rotating with a same
speed . So when it runs through a curve, the inner rail is having a small curvature than the outer rail. So Outer wheel has to travel a long distance than the inner wheel . So if both side's wheels are running with same speed, how it happens ? What is the magic here. Is it realted with Banking of curvature concepts. Please, anybody can provide some expert opinions for the above question..?
Thanks in advance..!:cool:
aneeshk said:
Hello,
No banking is necessary. The inner wheels slip on the rail.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
