How would gravity or any 1/r^2 force act in one dimension?
In a one-dimensional universe, gravity would act as a constant force, meaning distance does not affect the gravitational interaction, represented by F = GMMR. In two dimensions, gravity follows an inverse relationship of 1/R, while in three dimensions, it follows the 1/R^2 law, and in four dimensions, it becomes 1/R^3. The concept of 'flux' is introduced to explain how force laws vary with dimensions, where the amount of influence remains constant across distances in one dimension. The analogy of fluid dynamics illustrates that in higher dimensions, the force's effect diminishes with distance due to increased surface area. Overall, the discussion highlights how gravitational forces adapt based on spatial dimensions, emphasizing the unique behavior in one-dimensional scenarios.
zeromodz
From what I know, in 2 dimensions gravity works as 1 / R, 3 dimensions is 1 / R^2, and in 4 dimensions 1 / R^3
But what about one dimension? Is it just proportional to R? So the formula would be
F = GMMR?
Please explain in detail, how gravity would behave in one dimension and how exactly we get 1 / R^2 in two dimensions. Thank you!
In 1 dimension, it would just be constant (or 1/r0)
Wow, so that means that distance doesn't even matter in a one dimensional universe. Thats pretty interesting.
To discuss force laws in general let me first introduce the concept of 'flux'.
The word 'flux' comes from an analogy with the physics of fluids, so will use fluid as an example. Imagine a pool of fluid, and a tube extends into the pool, giving off a steady influx. Now surround the inlet with, say, a sphere that is made of a material that let's the fluid pass through. Clearly, the amount of fluid passing through the overall surface of the sphere is the amount that comes out of the inlet tube.
Surround with a yet bigger sphere: the same amount of fluid passes through the second sphere's surface. The surface area of a sphere is proportional to the square of the radius. This means that the velocity of individual fluid particles is inversely proportional to the square of the distance to the source.
Definition of 'flux':
In three dimensions of space an inverse square law has the following property: the flux of the force-field is the same at every distance to the source of the field.
(This 'flux' concept does not mean that gravity actually involves fluid flow, the analogy should not be taken literally.)
Now, one supposition (among other suppositions) is that whatever the number of spatial dimensions you want the force law to come out as a 'same flux at every distance' force.
Following that supposition you get 1/R for two spatial dimensions, and 1/R^3 for 4 spatial dimensions.
If you have just 1 spatial dimension, then 'same flux at every distance' means the same force at every distance.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
