How would I calculate the voltage
  • Thread starter Thread starter mnishi96
    Voltage
To calculate the voltage across the resistor in the given scenario, the magnetic field strength (B) can be derived using the formula F = BIL, where F is the force acting on the rod. Given the current (I) of 0.034 A and the length (L) of the rod at 0.18 m, B can be calculated as approximately 1601 T. Once B is known, voltage (V) can be calculated using V = BvL, resulting in a voltage of around 461.19 V. An alternative method to find voltage is using Ohm's Law, V = IR, which may simplify the calculation without needing the magnetic field strength directly. The discussion highlights the relationship between current, resistance, and voltage in the context of electromagnetic induction.
mnishi96
A 0.18m long metal rod is places on some metal rollers in a megnetic field directed into the page. When the rod is moved left with a speed of 1.6ms-1, a current of 0.034 A is measured through the 25Ω resistor.
How would I calculate the voltage when I'm not given the magnetic field strength? V=BvL
F=BI:
F=Bvq
V=Bvl
F=BIL
= 9.8=B*0.034*0.18
B=9.7/(0.034*0.18)
=1601T
V=BvL
V=1601*1.6*0.18
=461.19V..
I'm not sure if you can use 9.8 for the force,
please help
hi mnishi96! welcome to pf! :smile:
can't you just use V = IR ?
