I Perceived vs. Actual Velocity in an Expanding Universe
The discussion centers on the distinction between perceived and actual velocity in the context of an expanding universe, particularly regarding Hubble's observations of redshift. It clarifies that while the Hubble velocity is calculated as H0D, it should be viewed as a perceived velocity rather than an actual one, since the Hubble rate has different units than velocity. The interpretation of cosmological redshift can vary based on the coordinate system used, with both interpretations being valid locally. The conversation emphasizes that reality is defined by measurable quantities. Understanding these concepts is crucial for grasping the dynamics of cosmic expansion.
zapnthund50
According to what I've been taught, the distance-related redshift seen by Edwin Hubble is an artifact of an expanding Universe. That is, as light travels through space, space itself expands, redshifting the light (matter is embedded in space and does not itself expand but is instead carried along like raisins in a rising loaf of bread).
Ok. So assuming a mostly constant Universe expansion rate R, this means that the real velocity of a galaxy moving away from us would always be just R. However, the perceived velocity would always be H0D.
Is this correct so far, that is, should the Hubble Velocity be seen as perceived, not actual? Thanks!
Astronomy news on Phys.org
A rate is not a velocity, it does not even have the same units. The Hubble rate ##H## has units of 1/time whereas a velocity has units of length/time.
When it comes to interpreting "cosmological redshift" in terms of being an artefact of an expanding universe or an actual Doppler shift: It depends. Locally, both interpretations are equally valid and depend on the coordinate system you impose. See my Insight https://www.physicsforums.com/insights/coordinate-dependent-statements-expanding-universe/ Although it is written for A-level, you should be able to gain some understanding from it.
Likes JMz and zapnthund50
zapnthund50 said:
... this means that the real... However, the perceived...
Reality is the thing we measure.
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
Today at about 4:30 am I saw the conjunction of Venus and Jupiter, where they were about the width of the full moon, or one half degree apart. Did anyone else see it? Edit: The moon is 2,200 miles in diameter and at a distance of 240,000 miles. Thereby it subtends an angle in radians of 2,200/240,000=.01 (approximately). With pi radians being 180 degrees, one radian is 57.3 degrees, so that .01 radians is about .50 degrees (angle subtended by the moon). (.57 to be more exact, but with...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
