HW Check: Prove that the sequence {a_n} converges to 1/2
  • Thread starter Thread starter ironspud
    Sequence
4 replies · 4K views
ironspud
Hi,
Just hoping someone could check my work and point out any errors, if any.
Consider the sequence {[itex]a_n[/itex]} defined by [itex]a_n=\frac{n}{2n+\sqrt{n}}[/itex]. Prove that [itex]\lim_{x\to\infty}a_n=\frac{1}{2}[/itex]. (Do NOT use any of the "limit rules" from Section 2.2.)
A sequence [itex]a_n[/itex] is said to converge to a real number A iff for each [itex]\epsilon>0[/itex] there exists a positive integer [itex]n^*[/itex] such that [itex]\lvert a_n-A\rvert<\epsilon[/itex] for all [itex]n\geq n^*[/itex].
Proof:
Let [itex]\epsilon>0[/itex].
Let [itex]n^*\in\mathbb{N}[/itex] such that [itex]n^*>[\frac{1}{2}(\frac{1}{\epsilon}-1)]^2[/itex].
If [itex]n\geq n^*[/itex], then
[itex]\lvert a_n-A\rvert[/itex]
[itex]=\lvert\frac{n}{2n+\sqrt{n}}-\frac{1}{2}\rvert[/itex]
[itex]=\lvert\frac{2n-2n-\sqrt{n}}{2(2n+\sqrt{n})}\rvert[/itex]
[itex]=\lvert\frac{-\sqrt{n}}{2(2n+\sqrt{n})}\rvert[/itex]
[itex]=\lvert\frac{-n}{\sqrt{n}[2(2n+\sqrt{n})]}\rvert[/itex]
[itex]=\lvert\frac{-n}{\sqrt{n}(4n+2\sqrt{n})}\rvert[/itex]
[itex]=\lvert\frac{-n}{4n\sqrt{n}+2n}\rvert[/itex]
[itex]=\lvert\frac{-n}{2n(2\sqrt{n}+1)}\rvert[/itex]
[itex]=\lvert\frac{-1}{2(2\sqrt{n}+1)}\rvert[/itex]
[itex]=\frac{1}{2(2\sqrt{n}+1)}[/itex]
[itex]\leq\frac{1}{2\sqrt{n}+1}[/itex]
[itex]<\frac{1}{2\sqrt{[\frac{1}{2}(\frac{1}{\epsilon}-1)]^2}+1}[/itex]
[itex]=\frac{1}{2\lvert[\frac{1}{2}(\frac{1}{\epsilon}-1)]\rvert+1}[/itex]
[itex]=\frac{1}{2[\frac{1}{2}(\frac{1}{\epsilon}-1)]+1}[/itex]
[itex]=\frac{1}{(\frac{1}{\epsilon}-1)+1}[/itex]
[itex]=\frac{1}{\frac{1}{\epsilon}}[/itex]
[itex]=\epsilon[/itex].
You could have gotten here faster by dividing through by [itex]\sqrt{n}[/itex]...
[itex]=\lvert\frac{-1}{2(2\sqrt{n}+1)}\rvert[/itex] ...
It looks all right to me. I am presuming that you come up with the "mysterious substitution" [itex]\sqrt{[\frac{1}{2}(\frac{1}{\epsilon}-1)]^2}[/itex] for [itex]\sqrt{n}[/itex] by knowing that you're supposed to end up at "epsilon"...
Thanks dynamicsolo.
And, yeah, I get the substitution by knowing [itex]\frac{1}{2\sqrt{n^*}+1}<\epsilon[/itex]. Solving for epsilon, [itex][\frac{1}{2}(\frac{1}{\epsilon}-1)]^2<n^*[/itex]. And since [itex]n\geq n^*>[\frac{1}{2}(\frac{1}{\epsilon}-1)]^2[/itex], then [itex]\frac{1}{2\sqrt{n}+1}<\frac{1}{2\sqrt{[\frac{1}{2}(\frac{1}{\epsilon}-1)]^2}+1}[/itex].
That's OK -- everyone does that in these epsilon-delta proofs. Your choice should be acceptable because [itex]\epsilon(n) = \frac{1}{1 + 2\sqrt{n}}[/itex] is one-to-one, so there is no ambiguity in transforming between epsilon and n , and the limit is zero as n goes to infinity.
Yeah, I figured there was no problem in the substitution, though, maybe I should have provided the reasoning behind it in the proof. Oh well.
Anyway, thanks again.
