Hydrostatic pressure at a point inside a water tank that is accelerating
60 replies · 9K views
songoku
A cube-shaped tank is filled with water and attached firmly to a cart moving with an acceleration of 20 cm/s^2. Find the pressure at a point which is 10 cm deep and 10 cm from the wall of the tank.
I draw this diagram:
The formula for hydrostatic pressure is: ##P=\rho g h## so I just plug everything
$$P=1000 \times 9.8 \times 0.1=980 Pa$$
Will the acceleration of the cart affect the hydrostatic pressure?
Another thing that came to my mind was there would be extra force coming from normal force between water and left and right side of the tank and since the tank is accelerated to the right, normal force from the left part of the tank is bigger than the right part causing net force to the right.
But I am not sure whether I need to consider this to answer this question and how to proceed.
Thanks
Are you sure you are not supposed to measure ##10 \, \rm{cm}## deep as from the point on the wall where the water touches it on the far left? I believe this problem is leading you to find the slope of the water due to the acceleration of the cart. The depth will not be ##10 \, \rm{cm}## from surface in that case, you will have to determine it. Like you say, the problem is trivial otherwise.
I set up Newtons Second Law in a non-inertial frame, the coordinate ##x {}^+\leftarrow## is fixed to the front of the cart. The entire cart is accelerating to the right at ##a \rightarrow^-##. Look a thin vertical cross-section of length ##dx##, height ##h(x)## and mass ##dm##.
In the non-inertial frame of the cart there is an apparent acceleration of gravity vector $$\mathbf{g}_{\text{app}}=\mathbf{g}+(\mathbf{-a}).$$The surface of the liquid is perpendicular to the apparent acceleration vector. To find the pressure, you need to find the perpendicular distance ##d## from point A to the surface, then use $$p=\rho~g_{\text{app}}~d.$$You can read more about apparent acceleration of gravity here if you wish.
kuruman said:
find the pressure, you need to find the perpendicular distance d from point A to the surface, then use p=ρ gapp d.
You don’t, actually. If the situation is as depicted it is something of a trap to make you think you need to do all that. However, in an incompatible fluid in a constant gravitational field ##\vec g_{\rm app}## the pressure difference between two points separated by ##\vec d## is ##\rho \vec d\cdot \vec g_{\rm app}##. If you pick your reference point as OP did, then ##\vec d \perp \vec a## and ##\vec d \parallel \vec g##. Therefore the pressure difference is ##\rho g d##, where ##d## is 10 cm and ##g## the regular gravitational acceleration.
Alternatively you can reach the same conclusion by looking at the similar triangles for the distances and accelerations.
Yes, I see that now. I fell into the trap thinking of equal pressure planes below the surface.
It is a typical problem where knowing too much easily leads you astray whereas knowing not quite as much may give you the right answer but for the wrong reason.
On the other hand, if you try too hard to think outside the box you might fall off a cliff.
Did I fall off a cliff? I got that the slope was simply ##\frac{a}{g}##?
I am really sorry for late reply
Which similar triangles for distances and accelerations?
Lnewqban said:
I also think they are similar but I can not connect the dots
Thanks
Thanks
Is the shown sketch coming from the problem or you draw it yourself?
Regarding the question:
What is the meaning of “10 cm deep”?
From which wall of the tank?
What angle is formed between the surface and the horizon for that acceleration?
songoku said:
Homework Statement:: A cube-shaped tank is filled with water
So perhaps the cube has a lid, not open as you've drawn it.
That would resolve the issue of which wall the measurement is to be taken from. EDIT. Never mind, I believe the issue of which wall is still an issue either way.
I draw it myself, there is no picture from the original question
I interpret it as 10 cm from the surface of water which is now slanted because of the acceleration
I don't know so I just take one of the side
Not given. Do we need to find the angle?
Maybe but does it affect the analysis and calculation?
Thanks
Thanks
If it has a lid and is completely filled, I believe there is a positive pressure gradient opposite the direction of acceleration. So the pressure 10 cm down and 10 cm over will be different front to back. I think that is the same in either case.
10 cm down from what point on the slanted surface?
I will search about pressure gradient first then response back because I don't know what it is
Like what I draw in OP
Thanks
songoku said:
... I interpret it as 10 cm from the surface of water which is now slanted because of the acceleration
Should the measurement of that distance be perfectly vertical or perpendicular to the slanted surface?
songoku said:
... I don't know so I just take one of the sides.
I don't see how that horizontal distance is relevant, as each molecule of the fluid is subjected to the same vertical (gravity) and horizontal accelerations.
songoku said:
... Not given. Do we need to find the angle?
A vectorial addition of both accelerations would result in a total acceleration vector having certain angle respect to a vertical line.
Do you know which value of pressure is the correct answer for this problem?
Which, with the OP’s interpretation of the problem (with the 10 cm depth being measured from the surface right above the point) is not something you need to compute.
It removes any doubt re the meaning of depth here. It would also mean the top of the water above the point is not necessarily at atmospheric pressure.
The angle, or the a and g vector's summation?
Neither is relevant. You have a reference pressure at the surface directly above the test point. You have a known gradient of pressure along a vertical axis. What more do you need?
I think it's either what you have already solved... a question which basically tries to trip you up
or
The tank is completely filled as @haruspex interprets, and you have to do some analysis.
The other possible solutions seem to leave out too much information about where specifically this test point is relative to the walls.
I believe that the gradient of pressure is not known, unless calculated.
The point is, you only need the component of the pressure gradient in the vertical direction, which makes the acceleration irrelevant.
I believe in the case where it is an open top tank as drawn by the OP, the pressure at a depth (vertically) ##h## from any point on the surface is just ##P = \rho g h##.
The pressures from the acceleration and the hydrostatic pressure must be additive to produce the slope of the water; If they didn't add together then why would it slope? If we draw a horizontal line at some depth ##h## as a function of ##x## the distance from the leading wall of the tank, then the pressure at any point on that line is given by: $$ P = \rho g ( h + \frac{a}{g}x )$$ But if we draw a line parallel to the surface at depth ##h## from the leading edge the pressure at every point on that line is just: $$ P = \rho g h $$
Unless it's to be interpreted as @haruspex points out?
Yes, I am talking about the interpretation depicted in the OP.
I am probably wrong, as other members seem to imply, but I am totally missing that point.
I would love to see my error and to avoid misleading @songoku
The way I see it:
These two graphical situations are comparable to this problem in principle, if some relation can be established among static pressure inside the fluid in equilibrium and the total reaction of the represented bodies, also in equilibrium, at the support point.
The value of the unique static pressure at certain point inside the fluid, which is reacting to the horizontal acceleration of its container, can't be the traditional ρgh (pressure gradient in the vertical direction).
That point is supporting the force (each mass x common diagonal acceleration) of all the molecules that are aligned with the resultant acceleration vector and located between that point and the surface.
