Hypothesis on voltage homework
  • Thread starter Thread starter ccnv
    Homework Voltage
Changing voltage, magnetic field strength, and the number of loops in a coil in a DC motor can significantly impact its efficiency, as described by the efficiency equation. Torque in a DC motor is related to these variables through the equation τ=BAIN, where B is the magnetic field strength, A is the cross-sectional area, I is current, and N is the number of loops. To find torque, one can measure the time it takes for the motor to lift a constant mass at a constant height, using the force applied and the distance from the rotation axis. This approach allows for the calculation of torque based on the force exerted and the radius of the wheel involved. Understanding these relationships is crucial for proving the hypothesis on motor efficiency.
ccnv
I have make a hypothesis saying what changing voltage, magnetic field strength and number of loops in a coil in a DC motor do to effect efficiency using the efficiency equation below. I can't understand how torque is related at all.
mass and height are constant
I have no idea how to prove this
efficiency equation:
Eff=(mgh/t)/VI*100
torque in a dc motor:
τ=BAIN
B is magnetic field strength
A is cross sectional area of the coil in the motor, I is current, N is the number of loops in the coil.How can i find torque by timing how long it takes a motor to lift a constant mass at a constant height? Maybe that doesn't make sense? I don't even know anymore...
Eff=(mgh/t)/VI*100
τ=BAIN
You can get the force applied to the mass being lifted. You also need to know the distance from the string or rope (that lifts the mass) to the rotation axis of the motor. Often this is simply the radius of a wheel that the string is wound around.
From force and distance, you can calculate what the torque is.
