Hypothetical implication of Lorentz contraction
P Brane
Would it be possible for a truck, measuring 5ft tall when stationary, to pass under a 4ft barrier by accelerating towards the speed of light?
If so what would a spectator see if standing next to the barrier, would the spectator see the truck shrink? What would you see of the barrier from the trucks frame of reference, would the barrier seem to grow?
Sorry if my question appears unclear I couldn't think of another way to explain it. Thank you in advance for reading/attempting to answer the question.
There is no contraction in the transverse direction, so a five-foot tall truck will remain five feet tall in all reference frames.
There is a longitudinal contraction, and the longitudinal version of this asks why the contracted truck does not fall into a pothole. This is called the Thin Man and the Grid Paradox. See here.
Length contracts only in the direction parallel to the motion, not perpendicular to it. The height of the truck would remain unchanged in the road frame.
Thank you, that helped a lot. Do I now need to close the thread?
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
