I Beam Trolley Bearing Type
The discussion focuses on the differences between roller bearings and sleeve bearings used in I-beam trolleys. Roller bearings feature four wheels that roll along the bottom base of the I-beam, providing smooth movement. In contrast, sleeve bearings typically involve a different design that may not utilize wheels in the same manner. Visual aids were helpful in clarifying these distinctions for the participants. Understanding these differences is crucial for selecting the appropriate trolley type for specific applications.
sbaseball
I am having trouble finding the difference between and I beam Trolley with a roller bearing and a sleeve bearing?
I know that the roller bearing has 4 wheels that sit on the bottom base of the I Beam and roll back and forth but I am not sure how a sleeve bearing is different from that?
Thanks
Sounds like it's describing the bearings for the wheels on the I-beam roller itself, one type having a roller bearing and the other being a sleeve bearing.
Roller bearing:
Sleeve bearing:
I never got to thank you for your help, but those pictures really cleared up the difference between the two bearings.
Thank you
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
