I cant follow the logic of this proof
  • Thread starter Thread starter transgalactic
    Logic Proof
transgalactic
W_1 and W_ 2 are subspaces of V of inner product V.
prove that if
<br /> W_1\subseteq W_2<br />
then
<br /> W_1^\perp \supseteq W_2^\perp <br />
the proof is:
we take v\epsilon W_1
so <v,w>=0 for every w\epsilon W_1^\perp
and because
<br /> W_2^\perp \subseteq W_1^\perp <br />
(i can't see why the "viven expression is "true" why "because")
we get that
<v,w>=0
for every w\epsilon W_2^\perp
so v\epsilon W_2
so
Your latex is messed up a bit, but it looks like what you typed after "because" is intended to be the final conclusion, which doesn't make a whole lot of sense. What you want is
<v,w>=0 for all w in W2 then <v,w> = 0 for all w in W1 (because W1 is a subset) Hence v in W2perp implies v is in W1perp by the definition of the perpendicular subspace
sorry i ment
<br /> <br /> W_2^\perp \subseteq W_1^\perp <br /> <br />i can't see how they came to this conclusion after they defined v
we got two subspaces W1 and W2
W2 includes W1
they take "v" which is orthogonal to every vector which is orthogonal to W1
so v is parallel to W1 ,v is a part of W1 .
you say
"<v,w>=0 for all w in W2"
so all the vectors in w (W2) are perpendicular to v (which is W1)
no one told us that W2 is perpendicular to W1 ??
further more i was told that W2 include W1
W2 W1 cannot be orthogonal
The way to prove A is a subset of B is to start "if x is a member of A" and conclude "x is a member of B".
If x is a member of W_2^\perp then <x, v>= 0 for every member, v, of W_2. Since W_1 is a subset of W_2, every v in W_1 is a member of W_2 so <x, v>= 0 for every member of W_1.
ok i agree <v,x>=0 because W1 is a part of W2
what is the next logical step
its still doesn't give me the step i didnt understang
how did they get it?
v is perpendicular to W_1^\perp
v is perpendicular to W_2^\perp because W1 is a part of W2
so
one perpendicular member is a part of the other perpendicular member
but how to decide W2 perpendicular is a part of W1 perpendicular
why its not the other way around
how to deside?
Maybe a diagram would help. Here's a representation of the vector space V and the two subspaces, W_1 and W_2, with W_1 \subseteq W_2.
W_2^\perp is everything outside of W_2, but including the 0 vector.
W_1^\perp is everything outside of W_1, which means it includes everything in W_2 that's not also in W_1, plus everything that's outside of W_2, plus the 0 vector.
Now, any vector v \in W_1^\perp must be in
(W_2 - W_1) \cup \{0\} \cup W_2^\perp
\forall v \in W_2^\perp,
v \in W_2^\perp \cup (W_2 - W_1) \cup \{0\} = W_1^\perp.
Therefore, W_2^\perp \subseteq W_1^\perp
We know that every perpendicular vector of the larger subspace W_2 must be perpendicular to all vectors of any subspace within W_2; including the vectors making up W_1.
Thus, ALL vectors in the perpendicularity space of W_2, are elements in the perpendicularity space of W_1.
This means that the perp space of W_2 is contained in that of W_1
But, does it thereby follow that the perpendicularity space of W_1 is exhausted?
NO!
It might well include vectors of W_2 that happens to be perpendicular to every vector in W_1 as well!
Such vectors would NOT be part of the perpindicularity space of W_2, and therefore, one cannot say that the perp space of W_1 is contained within that of W_2
i can't see the attached diagram
"Thus, ALL vectors in the perpendicularity space of W_2, are elements in the perpendicularity space of W_1."
Because a non-zero vector in W_2 that is not in W_1 might be perpendicular to all vectors in W_1.
Since it by definition would be IN W_2, it cannot be perpendicular to every vector in W_2 (it is, for example, NOT perpendicular to itself!).
Thus, such a vector would be in the perpendicularity space of W_1, but not in the perpendicularity space of W_2
You should be able to see it now.
