I can't seem to find this limit
Lavender
I tried using the rule of multiplying with the "conjugate", for example what's above multiplied by (√n^3+3n)+(√n^3+2n^2+3)/(√n^3+3n)+(√n^3+2n^2+3).
But I'm left with a huge mess :(
I also tried dividing the top and the bottom by n^2 in the square roots to get the n out, but that didn't work either :(
The conjugate method looks good here. It doesn't give a mess in the numerator, right? In the denominator, do you need all the terms, or is it sufficient then only to look at the leading terms?
The image is so bad I can't even see the value of the exponents, try to write it out in latex next time.
Assuming what you wrote is ##\frac{\sqrt{n^3+3n}-\sqrt{n^3+2n^2+3}}{\sqrt{n+2}}##
multiplying with the conjugate works for me. After you done that note that only the "highest order" terms matter.
After you multiply by the conjugate, you want to pull the highest power of n, not ##n^2##, out of each of the square roots.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
