Understanding Voltage: A Fundamental Concept in Electric Circuits
  • Thread starter Thread starter Ant92
    Voltage
Voltage represents the potential difference in an electric circuit, indicating how much energy is needed to move a charged particle between two points. It is defined as energy per charge, with 1 volt equating to 1 joule per coulomb. Understanding voltage can be likened to gravitational potential, where work is required to lift an object against gravity, similar to moving a charge in an electric field. The discussion emphasizes that voltage is crucial for understanding how energy is transferred in circuits. Overall, grasping the concept of voltage is essential for mastering electric circuits in physics.
Ant92
I'm doing AS-level physics at the moment and we have moved onto circuits, current, etc. I feel a bit of an idiot but i cannot seem to describe in fully what voltage is. this is mainly because i don't really know. i understand that it represents the potential difference in a circuit, but i have limited understanding of that too. i can remember equations etc, regarding voltage, (V=IR, V=P/I, etc), i just cannot explain it if a question asks me too. any help would be appreciated.
thank you
My try at explaining it
It has some thing to do with the pd of a circuit which when all the the pd across a circuit is combined it is the same as the electromotive force provided by the power cell
If you can understand what gravitational potential is you can then understand what electrical potential is. Let's say you want to lift an object of mass m to height h. Now when you start to lift the object, gravitation starts to pull it down. If you want to beat the gravitiy you must do certain amount of work to get m to h.
Now electric potential is basically the same but the gravitation can change directions depending on the particles's charge. Now you have to plates one of them has a charge of Q and the other -Q and their distance is h. If you want to move a particle q from -Q to Q, you need to do certain amount of work. q is positively charged.
Does that help?
so are you saying that the potential difference, (i.e. voltage), is the potential energy that will be needed to move a charged carrier to different points around a circuit?
Yup, voltage = charge potential. And charge is polarized already, which comes in handy.
thankyou
voltage = energy per charge
Hi v! :smile:
All the electric units are connected to each other and to ordinary units …
for example 1 volt = 1 joule per coulomb …
voltage = energy per charge …
in other words, the voltage between two points tells you how much energy you get if you move a charge across. :smile:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
