I don't understand this simplification question for Power
  • Thread starter Thread starter chroncile
    Power
The discussion centers on expressing power in terms of electric charge, current, and voltage. It clarifies that power, defined as the product of voltage and current, simplifies to J/s, which is equivalent to watts. The participant expresses confusion about the question's intent, but it is confirmed that the derived result correctly shows that power is measured in watts. The simplification process is validated, indicating that the initial understanding of the relationship between the units is accurate. Ultimately, the participant has successfully arrived at the conclusion that power is measured in watts.
chroncile
Given that the unit of current is related to the units of electric charge and time by A = C/s, and the unit of voltage is related to the units of energy and charge by V = J•C^-1, express the power in terms of these other units. Simplify the result further, given that the watt (W) is defined by W = J/s
A = C/s
V = J•C^-1
W = C/s • J•C^-1
W = J/s
Now what? I don't understand what the question is asking.
They seem to be asking that since power is voltage times current, then it has units of J/s. Since a J/s is a watt, power has units of watts. You actually have the result.
