I dont understand why this is wrong. can someone me?
  • Thread starter Thread starter princessfrost
The discussion centers on a climber rappelling down a cliff and the calculation of the tension in the rope. The climber's weight and body position are considered, but the initial calculations were incorrect due to the misuse of angles. A correction was made regarding the angles used in the torque equation, specifically the relationship between the position vector and the force. After receiving guidance, the climber expressed gratitude for the clarification. Accurate angle usage is crucial for solving tension problems in physics.
princessfrost
Mountaineers often use a rope to lower themselves down the face of a cliff (this is called rappelling). They do this with their body nearly horizontal and their feet pushing against the cliff. Suppose that an 82.5 kg climber, who is 1.54 m tall and has a center of gravity 1.3 m from his feet, rappels down a vertical cliff with his body raised 28.9 degree above the horizontal. He holds the rope 1.46 m from his feet, and it makes a 24.2 degree angle with the cliff face.
http://session.masteringphysics.com/problemAsset/1039093/3/YF-11-33.jpg
a) What tension does his rope need to support?
I found the tension to be equal to - mg(1.3) sin(28.9) + T(1.3) sin(180 - 24.2-28.9)=0 and then i solve for T. T= (mg(1.3)sin(28.9))/(1.3sin(180-24.2-28.9)). I plugged in the numbers and found the answer to be 488.61 N but it's wrong. Can someone please help me? Thank you!
You are using the wrong angles. When using \tau = rF\sin\theta, the angle is the angle between the position vector (r) and the force.
ok i got it. thank you sooo much for your help! i really appreciated it!
